The brake diagram
for the Z600 shows the brake fluid leaving the master cylinder, going through a
proportioning valve to the passenger rear brake cylinder and then over to the driver
side rear brake cylinder. If you have fluid on the driver side cylinder, I would expect
to find fluid on the passenger side rear cylinder.
When you step on the brake, do you get any brake action on the left and right rear
brake cylinders?
Did you recently clean out your master cylinder? If so, when you disassembled it,
did it come apart easily or did it have a bunch of gunk in it? I recently worked on 2
master cylinders which had a spongy feel and one of the things which made a big
difference was making sure all the passages were cleaned out. In particular, under the two
front and rear outlet tubes (you need a 3/4 inch wrench to remove the nut) when I removed
the inner valve and spring I noticed 2 holes in each section. One hole was obvious and the other
was very small....... maybe 0.025 inches. I found the small hole to be plugged and when I cleared
it out with a fine steel wire the brakes worked properly.
Also, when you look at the bores of the master cylinder and the rear brake cylinder, it should be very
smooth and not showing major pitting or corrosion.
Looking for a car that's sporty, fun and fits in your budget?> I've got mine running but not stopping. Don't really know, > understand
> where the problem lies. If I ever get that figgered out I > may get some stopping power. Lines are all open MC seems operateble, > cleaned booster and it seems good, can bleed it and mc and front brakes.
> Get a little pedal and can stop but not too fast. I get fluid to driver > rear wheel but not to passenger side even tho the line is open. Pulled > driver wheel again thinking piston may have stuck and moved piston back and > forth. Still won't pump fluid to other wheel. Not knowing what is > wrong, it would cost the value of the car to buy rebuilt parts for complete > brake overhaul. Guess I keep plugging at it. Might get > lucky.
> Good luck on yours Mike.
> > Mike and Tami
> > Speer
> > Thursday, August 14, 2008 10:06
> > PM
> > RE: [2cylinderhondas] Honda
> > N600 trivial question
> > And after sitting
> > for 14 years the battery and cable may be just the beginning of what will be > > needed to get it running as I am finding out with my > > N600.
> > So far everything
> > you have mentioned for me to check on mine is just as you said Bill, Im > > getting more things ironed out but I still dont have mine > > running.
> > Mike
> > [mailto: 2cylinderhondas@ yahoogroups. com ]
> > On Behalf Of
> > billmyong@earthlink .net
> > Thursday, August 14, 2008 7:57
> > PM
> > Ok, ready set
> > think... it's a 12 volt battery and 12 volt system with a couple of > > hundred cranking amps (depending on the battery). The wire will be the > > same for all 12 volt systems. Go to the local Auto Zone and pick up > > the right length of battery cable. This is not rocket science.
> > > -----Original
> > > Message-----
> > > [mailto: 2cylinderho ndas@yahoogroups .com ]
> > > On Behalf Of
> > > gary cushman
> > > Sent:
> > > Wednesday, August 13, 2008
> > > 12:51 PM
> > > Re: [2cylinderhondas] Honda
> > > OOOhhhh the M word.....I was repremended
> > > for that nasty word!! I looked at my Battery Cables and they are more like > > > a light car cable, I dont have the foggiest idea of gage? these are > > > originals on my car, I was at Walmart looking at the no lead cables, which > > > are the same size as mine
> > > G
> > > ----- Original Message ----
> > > From: mafoose_zxt
> > > Sent: Wednesday,
> > > August 13, 2008 12:46:53 PM
> > > Subject: [2cylinderhondas] Honda N600
> > > trivial question
> > > On
> > > the quest to get my car that's sat for almost 14yrs running, I have > > > a > > > quick question.
> > > What size (gauge) wire should I run from the
> > > battery to the starter?
> > > It's basically a motorcycle right? On
> > > motorcycles that wire is like
> > > 10-12 gauge, is that enough for this
> > > car?
> > > Thanks!
> > > Mario
> > No virus found in this incoming
> > message.
> > Checked by AVG - http://www.avg. com
> > Version: 8.0.138 /
> > Virus Database: 270.6.3/1611 - Release Date: 8/14/2008 6:20 > > AM
Read reviews on AOL Autos .
