Re: Need help
Alexander G. Penalosa
Re: Need help
Post by Alexander G. Penalosa »
My '72 AZ600 was starting and running a week ago and now I can't seem to make it start although itr cranks.  Have read from the email threads about similar problems which might concern clogged fuel lines or problems with the carburetor.  I don't have the faintest idea as I am not even an amateur mechanic.  I would greatly appreciate any recommendation If you or you know of someone within a radius of 100 miles from Concord, CA (so I can have the car towed to the location) who could fix this problem and an approximate of how much it would cost.
Alex
Bill Tucker
Re: Need help
Post by Bill Tucker »
Alex; pull a plug and lay it against the head and see if you are getting spark as you crank the motor, if so pull the fuel line off the carb and turn the key on with out trying to start the car, it has a electric fuel pump so it will pump fuel up with out trying to start the car, if your fuel pump is working and your getting spark it could be several things so, it my be time to get a mechanic involved to do more in-depth checks.
Just a couple of things to check good luck.
Re: Need help
Alex,
   I had a car which ran fine but if it sat for several months,  it would not start (although it did crank ok).  I would change the spark plugs and it would run fine.  The plugs I was running in that car were Nippondenso and not NGK but I did not think the spark plugs were really the problem.  It turns out the high voltage out of the ignition was on the weak side and that was the real problem and the energy from the ignition was not sufficient to break through any oxidation which had formed on the plug tips.
> My '72
> AZ600 was starting and running a week ago and now I can't seem to make it > start although itr cranks.  Have read from the email threads about > similar problems which might concern clogged fuel lines or problems > with the carburetor.  I don't have the faintest idea as I am not even an > amateur mechanic.  I would greatly appreciate any recommendation If you > or you know of someone within a radius of 100 miles from Concord, CA (so I can > have the car towed to the location) who
One site keeps you connected to all your email: AOL Mail, Gmail, and Yahoo Mail.
Try it now .
Re: Need help
Thanks  Bill, I'll give it a try.
Bill Tucker To:
Monday, December 29, 2008 12:49:49 PM Subject:
RE: [2cylinderhondas] Re: Need help
Re: Need help
Thanks for the info Dale.
"goinhm@..." To:
Monday, December 29, 2008 1:24:26 PM Subject:
Re: [2cylinderhondas] Re: Need help
Alex,
> My '72
Try it now .
Re: Need help
Post by Miles »
Sounds like you jumped timing, very common. Do you know how to turn
the car off? Before you crank it anymore, remove both plugs and
rotate the engine by hand a couple times with a 17mm wrench on the
crank pulley.
If you feel resistance with the plugs out then you are clashing a
valve into a piston. If this is it then remove the valve cover and
check the timing, if the timing is off you might get lucky, but
doubtful and you can move the chain back. Check the cam sprocket for
broken teeth and check the slack on the chain.
I am in Santa Cruz Mtns, I could come to you to see what's going on,
but if it needs major work then I would request you bring the car to
me.
Re: Need help
Hi Miles, Here is my address:
2725 Richard Ave.
Concord, CA   94520 Cell No. XXX-XXX-XXXX I forgot to mention during our phone conversation that if you have available I need too a replacement for the air-cleaner-to-carburetor bellows.
Thanks and Happy new Year.
Miles To:
Tuesday, December 30, 2008 9:19:24 PM Subject:
Sounds like you jumped timing, very common. Do you know how to turn the car off?  Before you crank it anymore, remove both plugs and rotate the engine by hand a couple times with a 17mm wrench on the crank pulley.
If you feel resistance with the plugs out then you are clashing a valve into a piston. If this is it then remove the valve cover and check the timing, if the timing is off you might get lucky, but doubtful and you can move the chain back. Check the cam sprocket for broken teeth and check the slack on the chain.
I am in Santa Cruz Mtns, I could come to you to see what's going on, but if it needs major work then I would request you bring the car to me.
Miles XXX-XXX-XXXX
Eddie Velasquez
Re: Need help
Post by Eddie Velasquez »
sounds like points and condensor, are you getting a spark? check this by pulling off one spark plug wire , sticking a screw driver in it hold the handle of  the screw driver one eighth inch to the engine block, and have some-one crank the car. You should have a spark jumping off the screwdriver to the block. this means you do or do not have fire. careful not to shock yourself
Mon, 12/29/08, Alexander G. Penalosa
> From: Alexander G. Penalosa
> Subject: [2cylinderhondas] Re: Need help
> Date: Monday, December 29, 2008, 1:48 PM
> Thanks,
> Alex
Re: Need help
thanks Eddie.
I would like to take this opportunity to thank Miles Chappel (www.600miles.com) for doing a great job of coming over to my place to tune and correct the timing of my AZ600.  My 600 is now starting right up and the engine runs smoother.  Thanks a lot Miles and I am sure there are a lot of other folks like me who have benefited well from your expertise and services.  I would also like to thank everybody who has extended their expertise and experience and it sure is a great thing to be a member of this group.
Alex
Eddie Velasquez To:
Monday, January 5, 2009 12:22:07 AM Subject:
> Thanks,
> Alex
