front axles
D
front axles
Post by D »
do I need a puller to remove the front cv shafts from a 72 sedan?? thanks anyone
Re: front axles
I remove the cv joint at the differential and then use a 2 jaw gear puller to press the shaft from the knuckle (where two front wheel bearings reside).  When you have the cv joint free,  put some type of covering (e.g. plastic bag) over it to keep dirt out and catch any ball bearings which may fall out.
> do I need a puller to remove the front cv shafts from a 72 sedan?? thanks > anyone
dean m
Re: front axles
Post by dean m »
that was one of my thoughts , thanks for the back up im gonna go for it........ cheers
Sun, 11/8/09, goinhm@...
> From: goinhm@...
> Subject: Re: [2cylinderhondas] front axles
> Date: Sunday, November 8, 2009, 3:17 AM
> I remove the cv joint at the differential and then use a 2 jaw gear puller > to press the shaft from the knuckle (where two front wheel bearings > reside).  When you have the cv joint free,  put some type of covering > (e.g. plastic bag) over it to keep dirt out and catch any ball bearings which > may fall out.
> good luck,
> > do I need a puller to remove the front cv shafts from a 72 sedan?? thanks > > anyone
