anzhonda600owners@yahoogroups.com]
> T W
> S
> Saturday, April 16, 2011 9:24 PM
> RE: [anzhonda600owners]
> Rear Brake Fluid Leaking
> Bill, i only said honing because i thought the
> cylinders are hard to come by and was hoping his was the best case > scenerio in that the pistons still function and arent seized. not dealt > with them but sounds like they are hard to come by? also, i cant > remember if i brought it up in this group quite awhile back of if it was > with another group im in but would silicon brake fluid make these brake > systems hold up better? Silicon displaces moisture which is what seems > to destroy brake systems. I dont have any experiance here but the > problem isnt unique to Hondas so why dont most cars brake > systems just have silicon? Tim > --- On > Wed, 2/6/02, > billmyong@...
> > billmyong@...
> > RE: [anzhonda600owners] Rear Brake Fluid Leaking > > To:
> > Date: Wednesday, February 6,
> > 2002, 9:52 PM
> > Marty;
> > Honing will
> > most likely not solve the problem. Look at the wheel cylinders > > and see if there is any corrosion (pits in the cylinder) If > > honing will remove them, it might work. Then too, the piston > > could be corroded and the leak is coming from under the round > > seal. If that is the case, honing will not solve the > > problem.
> > There is one
> > advertiser that is resorting the Honda 600 rear wheel cylinders, from > > soup to nuts. That is White Post restorations.
http://www.whitepost.com/brake.html
> > and they
> > have a life time warrantee.
> > Rule of
> > thumb, change your brake fluid often at least annually. You know > > how ugly and blackish the fluid looks in your Master Brake Reservoir?
> > Will that comes from the metal piston moving back and forth inside the > > cylinder which is much like the rag used to polish your bright > > work. It becomes black and sooty. The same thing happens > > in your brake system. And, DOT 3 fluid absorbs moisture, it's > > supposed to. And in about two years the DOT 3 in your brake > > system is 50% moisture. Which is corroding the cylinders.
> > Easy fix, change it (DOT 3
> > fluid) often.
> > So why don't the front calipers
> > do the same. They do, its just that the piston's float across > > the rubber seal rather than dragging it over the cylinder.
> > Maybe we can put calipers on the
> > rear wheels?
> > > -----Original
> > > Message-----
> > > [mailto:
anzhonda600owners@yahoogroups.com] > > > On Behalf Of
> > > juniselect
> > > Sent:
> > > Saturday, April 16, 2011 5:35
> > > PM
> > > Leaking
> > > Hey fellow 600 enthusiasts,
> > > Took the sedan out today and
> > > noticed there was a small puddle in the garage where the driver's > > > side rear wheel rested. Looked closer and saw a small trickle of > > > brake fluid down the inner side wall of the tire. Took off the wheel > > > and inspected the rear brake cylinder. when i squeezed the rubber > > > base of the cylinder i had brake fluid come out and when i let go, > > > it seemed to "inflate" again. Didn't check to see if the other side, > > > (which doesn't leak) because I wanted to pitch this situation to the > > > group. Any ideas on what is going on?
> > > Thanks so
> > > much!
> > > Marty
> > > San Francisco,
> > > CA
