Sorry if it offends those of you who have everything for your car.
For everyone else we have added more parts than a couple of people worth of fingers and toes!
Rear shocks, oil seals, o-rings, wheel bearings, left rear wheel cylinders and more.
http://www.honda600carparts.com
Commercial Announcement
Carb Kits
JC Whitney sells the Honda Gold wing carburetor repair kit for the 1975 GL1000 Part number CBJO10983 for $39.99 that will work as a rebuild kit for your Honda 600 second generation carb. Only one of the jets will work and the ears on the float bowl gasket need to be trimmed. The needle valve housing opening is to small for the Honda 600 carb, the needle will work, but the O rings are perfect and with a good cleaning, using these O rings the carb will work great. Check it out.
Rear Shocks for the Honda 600 Sedan and Coupe
Check it out Shocks for your Honda 600 just $27.83 - to - $27.79 they bolt right in.
$27.82
http://www.amazon.com/KYB-343143-GR-2-S ... B000C42R2I
$27.79
http://www.rockauto.com/catalog/raframe ... 3143-26350
$27.83
http://www.summitracing.com/parts/KYB-343143/
$27.82
http://www.ajusa.com/details/index/690/ ... KYB+343143
$27.82
$27.79
$27.83
$27.82
