cooling fan mounting bolts
hedoshedo2
Im wondering if studs and nuts would be a better solution than the factory bolt set up...comments?
Miles Chappell
Re: cooling fan mounting bolts
There's not enough room to slide the fan back and clear the studs. I
have a GL1000 electric cooling fan on my coupe so there is no side load on the bolts
to shear off the bolts at the head & cylinders. And there's no squeeking from bad
bearings and belt. And your clutch cable won't get cut in half when it rides on the
adjusting pulley.
adjusting pulley.
Robert James
The electric fan is intriguing. �Is it always on and how much does it draw?
Bob Tracy
Bob Tracy
On Thu, Sep 4, 2014 at 2:35 AM, 'Miles Chappell #10321'
z600miles@...
[2cylinderhondas]
> my�coupe so there is no side load on the bolts
> adjusting pulley.
I've been running mine for about a year now and have had no problems. I believe I got a little extra power out of the deal as well not having to drive the old fan with the belt. I do have mine on all the time, it's wire thru a relay off the ign. I do not know what the actual draw is but it's not much, the fan only has 18ga wire and a 5amp fuse. If your not trying to restore the car back to stock then I would recommend the swap to anyone that wants to improve the performance.
MicroMonster Kurt
MicroMonster Kurt
On Sep 4, 2014, at 6:27 AM, "Robert James
rjamesblues@...
[2cylinderhondas]" wrote:
The electric fan is intriguing. Is it always on and how much does it draw?
Bob
Tracy
z600miles@...
[2cylinderhondas]
> adjusting pulley.
Robert James
Thanks, I will probably pick you brain later for details on mounting!
Sent from my iPhone
Sent from my iPhone
On Sep 4, 2014, at 6:52 AM, "Kurt
micromonster02@...
MicroMonster Kurt
rjamesblues@...
> Bob
> Tracy
> z600miles@...
> [2cylinderhondas]
> > adjusting pulley.
> > Miles
Dr. Whiting
From a practical sense, studs would make the removal of the fan housing more difficult. Not much clearance to start with and there is no improvement in strength.
Bryan O_Shaughnessy
Jeez, why didn't we all think of this? Gain slight horsepower, no belt maintenance or replacement, faster delivery of engine heat to the cabin...
Good on ya'!
On Thursday, September 4, 2014 10:09 AM, "Dr. Whiting theenginebuilder@... [2cylinderhondas]" wrote:
Good on ya'!
Bryan O_Shaughnessy
...and the opportunity to install a thermostat for the best op temperature.
> Good on ya'!
> On Thursday, September 4, 2014 10:09 AM, "Dr. Whiting theenginebuilder@... [2cylinderhondas]" > wrote:
Actually the fan speed is factored in with the speed of the engine giving you the best cooling option, IMHO.
An electric fan is one speed.
The pulleys look awesome, I like the way they look, makes the car that much more unique.
Sent from my T-Mobile 4G LTE Device
-------- Original message --------
From: "Bryan O'Shaughnessy bryanoshaughnessy@... [2cylinderhondas]"
Date:09/04/2014 2:54 PM (GMT-08:00)
Subject: Re: [2cylinderhondas] Re: cooling fan mounting bolts
> Good on ya'!
I am running an electric fan and custom heat shields. This allowed me to add an alternator. I also have EFI and the engine temp is monitored all the time. Once cursing the fan can be turned off.
Some picks Japanese Nostalgic Car " View topic - My AN600s
Here is my latest experiment. The main bracket is steel angle welded to the front motor bracket. The alternator is from a Geo and is bolted to an aluminum plate.
View on japanesenostalgicca...
Preview by Yahoo
Preview by Yahoo
