Re: [2cylinderhondas] an 600 brake lines
Post by Lyle »
Hi Jon Mistchenko ;
I am not clear on what your threading your new brake line into.  But, as already stated, all threads are metric on the Honda. And as Larry said, don't try and tighten it as there will be (Hell) to pay trying to thread in a metric end later.
The Hex end of the fitting is for a 10mm wrench, but the thread diameter is 8mm, 1.0 thread pitch if memory serves me correctly as I don't have one sitting with me as I answer this e-mail at 3 am.  You should have the one you removed to use as a comparing item when you go to the parts store. But if you told the parts guy at the store what it was for when you purchased the first one, and he sold you a SAE then I'd look for another parts guy.
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Larry Cooley > Sent:
> Sunday, October 09, 2005 10:02
> The "flare nuts" on
> the brake lines are a 10 mm thread... the brake lines with  the proper > nuts  can be purchased  at  Bap Geon and Napa  auto parts > outlets in lengths that vary in 10 inch increments!!
> I hope you did not try
> to tighten the 3/16 line...the brass fittings are kind of soft!!
> Back on
> the street soon?!?!
> C'Ya
> Larry Cooley
> Wayne Linschied wrote:
> > Could they be Metric?  Most Hondas
> > are.
> > Wayne
> > From: "Jonathan
> > Mistchenko and Sarah Reeves"
> > Sunday, October 09, 2005 6:00 PM
> > Subject: [2cylinderhondas] an 600 brake
> > lines
> > > I am replacing the long brake line to the back of the
> > car and the 3/16"
> > > lines I bought don't seem to be the right thread
> > pitch...they screw
> > together
> > > for a few rotations and then get very
> > tight before the flared end of the
> > > line has contacted its mating
> > surface.  Do I need lines with a special
> > > thread on the
> > nuts?  If so, where can I get them?
> > Thanks,
> > > Jon
> > Mistchenko
> > > Yahoo! Groups
> > Links
tloch220
Post by tloch220 »
I am replacing the longest line to the back because it is plugged with dried brake fluid, so I am threading the lines into the MC and the porportioning valve near the rear axle.  I guess a few turns is not enough to know if the threads are truly compatible.  I thought I grabbed lines from a box that said "metric", but I just looked and the label on the actual lines says nothing about the threading.  I will go to NAPA tomorrow and make sure I get the right ones.  I only tightened the MC end finger tight (and got a nice brake fluid puddle on my garage floor overnight), but I did use a wrench on the porportioning valve so I may need to steal the one from my other 600.
Thanks again for the help.  I plan to get to the DMV this week and register this car so I can start driving it instead of just lying under it.
Jon
