I wanted to know if anyone out there knows what the wheel bolt pattern
is for the n600? I've measured it and it's around 110mm but I'm not
sure that's the factory spec. Any help?
bolt pattern
Re: bolt pattern
Yes, it is 110mm. Also the same size found on Mazda wheels.
Bruce
----- Original Message ---- From: jennings93463 To: anzhonda600owners@yahoogroups.com Sent: Tuesday, May 22, 2007 10:54:22 PM Subject: [anzhonda600owners] bolt pattern
I wanted to know if anyone out there knows what the wheel bolt pattern is for the n600? I've measured it and it's around 110mm but I'm not sure that's the factory spec. Any help?
Bruce
jennings93463
Re: bolt pattern
--- Hi Bruce, Thanks for the info!
Which Mazda has the same wheels as the honda?
Do you also know what diameter the Mazda wheel is?
Robert
Robert
> Bruce
> From: jennings93463
Re: bolt pattern
Robert,
This is an often asked question in this forum. Yes, some Mazda 13" wheels with low aspect tires will fit, however it isn't recommended, cause they weigh a lot more than stock or mags for 10" wheels. It's a clearance problem too.
Stick with the stock setup.
Bruce
Currently holding at 2 sedans & 1 coupe
----- Original Message ---- From: jennings93463 To: anzhonda600owners@yahoogroups.com Sent: Wednesday, May 23, 2007 4:03:03 PM Subject: [anzhonda600owners] Re: bolt pattern
Bruce
help?> Yes, it is 110mm. Also the same size found on Mazda wheels.
> Bruce
> From: jennings93463
> I wanted to know if anyone out there knows what the wheel bolt pattern > is for the n600? I've measured it and it's around 110mm but I'm not > sure that's the factory spec. Any
