Anyway, I have a couple of master cylinders I'd like to get re-sleeved. So, you recommend moving to DOT5? I've never had to replace the DOT3 fluid in any car I've owned. Is there a reason why you would change it so often? Moisture build-up? Is DOT5 more corrosive than DOT3?
kev
Wed, 8/3/11, billmyong@...
Subject: RE: [anzhonda600owners] Re: Parts Supplier Needed
Date: Wednesday, August 3, 2011, 12:51 AM
Hi Kev;
This is from their site, and they do say they will brass sleeve your cylinders. Brass sleeving is a normal service to bringing back warn aluminum brake cylinders. Using DOT5 brake fluid keeps your brake system running for a long time. Yes there is maintenance, but the amount of maintenance using DOT5 compared to DOT3 is far less.
The alternative is to change out your DOT3 fluid every other year or less. I change out DOT5 about every 5 to 6 years. Yes there have been cylinders that had to be rebuilt, but the inside of the cylinder on a vehicle using DOT5 is just like the day it was put together. The only issue I have had is corrosion on the pistons under the seals where the fluid was changed over to DOT5 with out doing a complete rebuild. There was some DOT3 left under the seal that caused the piston seal area to corrode and fail. Attention to detail is the key, working with used parts can be costly, that is why using a resource like White Post Restorations is a good idea.
www.whitepost.com
The
ULTIMATE
Solution to Your Brake Cylinder Problems.
White Post Restorations has a unique brake cylinder sleeving and rebuilding service, the ultimate solution to your brake cylinder problems.
Click here for our Brake Service Request Form
Our rebuilt cylinders are better than new, they will never rust, pit or corrode, because we install brass sleeves.
We disassemble the cylinders, glassbead clean, bore oversize, press in the brass sleeve and size them to original specifications. We rebuild your cylinder with all necessary new parts and apply an original finish on the outside.
We rebuild vacuum boosters for all cars and trucks.
We also reline brake shoes and disc brake pads.
All work is guaranteed with a written Lifetime Warranty.
Quick Service - Same Day & Overnight. (Normally 2 to 3 Days.)
When you receive your rebuilt brake cylinders, they're ready to bolt on your car, and you'll never have to touch them again!
