front strut replacement
promoter213
Post by promoter213 »
Hi everyone, just changed out the rear shocks on my sedan to some kyb shocks. Now its time to get the front going. Does anyone know of a alternative/replacement part that's compatible? Thanks to Bill ive read the tutorial on refilling the front struts, which I will do if that's the only option.
However I dont see any signs of a leak, so if there is no leak how would replacing the oil make a difference? Wouldnt it mean the internal components are worn? If so, is buying a rebuild kit the way to go? Or does a mere change and refill do the trick. Does the oil get worn too thin and not do its job?
Sorry for not knowing obvious info. thanks everyone.
Re: front strut replacement
In a word yes, the strut oil will loose its viscosity over time and there is contamination from just moving up and down and rubbing against the bushings and seals.
Changing the oil in the strut really helps.  Is there a cartridge to replace what is there?
Not that I know of.
Although there is a Honda 600 owner who is making a replacement strut.
Garm Beall at mcroimg@...
If you are pulling your strut apart look at these items.
promoter213
morning everyone,
anybody know the correct amount of oil that should be replaced to rebuild front strut.
thanks
Go to Photo Album - has a power point how to-
https://groups.yahoo.com/neo/groups/anz ... /845817088
The Century Club
Post by The Century Club »
Thanks for the link Bill.
I did take the time to review the slide. My concern is if there is an actual number of ounces versus what is taken out. One side of my damper had more than 3.5 ounces and the other had less.
The slide indicates 3.5 ounces was taken out and an equivalent should be replaced.
Is there a standard amount that it should be filled with as a factory setting?
Sorry for making things complicated just want to make sure I do this correctly.
How many ounces of oil has everyone else been replacing?
On Fri, 4/29/16, 'Bill'
billmyong@...
[anzhonda600owners] wrote:
Subject: RE: [anzhonda600owners] front strut replacement
Date: Friday, April 29, 2016, 12:09 PM
Go to Photo Album -
to-
[mailto:
Sent: Friday, April 29,
2016 10:53 AM
morning everyone,
anybody know the
thanks
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXX --
#yivXXX-XXX-XXXXygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px
0;padding:0 10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp hr {
border:1px solid #d8d8d8;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXhd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp #yivXXX-XXX-XXXXads {
margin-bottom:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad {
padding:0 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad p {
margin:0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mkp .yivXXX-XXX-XXXXad a {
color:#0000ff;text-decoration:none;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-sponsor
#yivXXX-XXX-XXXXygrp-lc {
font-family:Arial;}
#yivXXX-XXX-XXXXygrp-lc #yivXXX-XXX-XXXXhd {
margin:10px
0px;font-weight:700;font-size:78%;line-height:122%;}
#yivXXX-XXX-XXXXygrp-lc .yivXXX-XXX-XXXXad {
margin-bottom:10px;padding:0 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span {
font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span:first-child {
text-transform:uppercase;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span a {
color:#5085b6;text-decoration:none;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXactivity span span {
color:#ff7900;}
.yivXXX-XXX-XXXXunderline {
text-decoration:underline;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
0;width:400px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach div a {
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach img {
border:none;padding-right:5px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label {
display:block;margin-bottom:5px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXattach label a {
#yivXXX-XXX-XXXX blockquote {
margin:0 0 0 4px;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXbold {
font-family:Arial;font-size:13px;font-weight:700;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXbold a {
#yivXXX-XXX-XXXX dd.yivXXX-XXX-XXXXlast p a {
font-family:Verdana;font-weight:700;}
#yivXXX-XXX-XXXX dd.yivXXX-XXX-XXXXlast p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
span.yivXXX-XXX-XXXXyshortcuts {
margin-right:0;}
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table div div a {
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXattach-table {
width:400px;}
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXfile-title a, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:active, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:hover, #yivXXX-XXX-XXXX
div.yivXXX-XXX-XXXXfile-title a:visited {
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:active,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:hover,
#yivXXX-XXX-XXXX div.yivXXX-XXX-XXXXphoto-title a:visited {
#yivXXX-XXX-XXXX div#yivXXX-XXX-XXXXygrp-mlmsg
#yivXXX-XXX-XXXXygrp-msg p a span.yivXXX-XXX-XXXXyshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXgreen {
color:#628c2a;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXMsoNormal {
margin:0 0 0 0;}
#yivXXX-XXX-XXXX o {
font-size:0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div {
float:left;width:72px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div div {
border:1px solid
#666666;height:62px;overflow:hidden;width:62px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXphotos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXreco-category {
font-size:77%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXreco-desc {
font-size:77%;}
#yivXXX-XXX-XXXX .yivXXX-XXX-XXXXreplbq {
margin:4px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean,
sans-serif;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg table {
font-size:inherit;font:100%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg select,
#yivXXX-XXX-XXXX input, #yivXXX-XXX-XXXX textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg pre, #yivXXX-XXX-XXXX
code {
font:115% monospace;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg * {
line-height:1.22em;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-mlmsg #yivXXX-XXX-XXXXlogo {
padding-bottom:10px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-msg p a {
font-family:Verdana;}
p#yivXXX-XXX-XXXXattach-count span {
color:#1E66AE;font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-reco
#yivXXX-XXX-XXXXreco-head {
color:#ff7900;font-weight:700;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-reco {
margin-bottom:20px;padding:0px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-sponsor #yivXXX-XXX-XXXXov
li a {
font-size:130%;text-decoration:none;}
li {
font-size:77%;list-style-type:square;padding:6px 0;}
ul {
margin:0;padding:0 0 0 8px;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text {
font-family:Georgia;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text p {
margin:0 0 1em 0;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-text tt {
font-size:120%;}
#yivXXX-XXX-XXXX #yivXXX-XXX-XXXXygrp-vital ul li:last-child {
border-right:none !important;
#yivXXX-XXX-XXXX
3.5 is a round number, add if you feel it will take it.   I did on my coupe strut.
