Timing rollers
twincarb600
Re: Timing rollers Material?
Post by twincarb600 »
I just uploaded the lower roller picture. Misc folder
, "twincarb600" wrote:
> I just uploaded a picture of the upper roller. Look in the Misc photo folder.
> > I have some of these from Auto-Spot. The upper roller is made out of steel with 1 bearing machined into it. The lower roller has 2 ball bearings and nylon. I never purchased the drive chain roller. I think when I got mine they didn't offer the them yet.
, Jerry A wrote:
> > > Correct, the Japanese units use nylon with ball bearings for the tensioner (toothed) wheel and what looks like machined aluminum with either bushing or roller bearing depending on which one you want. I am interested in his prices as units from Japan are about $120 each by the time they make it to your door.(depending on currency exchange rate of course). www.auto-spot.net is one of the Japanese suppliers.
> > > --- On Wed, 5/11/11, twincarb600 wrote:
> > > From: twincarb600
> > > Subject: [2cylinderhondas] Re: Timing rollers Material?
> > > Date: Wednesday, May 11, 2011, 3:12 AM
> > > The rollers from Japan I think are nylon for the bottom and steel for the top roller. The ones from Japan use ball bearing and not bushings. I have bought several from Japan but have never used them yet. I'll look closer the next time I'm digging around.
, "Lyle" wrote:
> > > > Like Miles I am wondering what the material is?
> > > > Delrin and most plastics will not take the heat and pressures of a high rev timing chain.
> > > > Some nylons have been used on water cooled engines, but an air cooled engine is running much higher temp's.
> > > > It would be great if you found a material that will work.
> > > > Any info or test info would be useful if you want to sell these.
> > > > Japan was selling rollers, but not sure how they held up to hours of use.
> > > > Lyle
> > > > --- In
, "feltonminicycle" wrote:
> > > > > I made and tested rollers made of Delrin (Acetal Plastic) 10 years ago and the guide roller could not hold the temperature. I installed and removed the melted roller myself from a customer's car.
> > > > > What is the material in these rollers shown?
> > > > > Miles
> > > > > --- In
, "Steve A" wrote:
> > > > > > Does anyone need lower and upper timing chain rollers and primary
> > > > > > I have a set of them and they are great quality needle bearing in the lower one
> > > > > > bronse others let me know if interested I will pass email to you
I don't know about aluminum as a material for the center roller.  The metal is soft and the cam chain will chip away at it causing these chips to fall into the oil and get trapped in the roller cages of the crankshaft.  Ultimately causing excessive wear in the crankshaft roller cages and destroying the crank shaft.  I looked at making them out of stainless but thought the price high.
-----Original Message-----
bottom cop
Post by bottom cop »
Do you have the part numbers on these and the web site/phone number for the Auto-spot where these came from?
> From: twincarb600
> Date: Wednesday, May 11, 2011, 10:12 PM
> > From: twincarb600
> >       The rollers from Japan I think are nylon for the bottom and steel for the top roller. The ones from Japan use ball bearing and not bushings. I have > bought several from Japan but have never used them yet.  I'll look closer the next time I'm digging around.
> > > Japan was selling rollers, but not sure how they held up to hours of > use.
> > > Lyle
> > > > Miles
> > > > --- In
twincarb600
http://auto-spot.net/parts/g-roller.html
http://auto-spot.net/parts/tensioner.html
I had to purchase thru a broker in order to get them. Auto-Spot wouldn't deal directly with someone out side of Japan.
> From: twincarb600
> I have some of these from Auto-Spot.� The upper roller is made out of steel with 1 bearing machined into it.� The lower roller has 2 ball bearings and nylon.� I never purchased the drive chain roller.� I think when I got mine they didn't offer the them yet.
> > From: twincarb600
> >� � ���The rollers from Japan I think are nylon for the bottom and steel for the top roller. The ones from Japan use ball bearing and not bushings. I have bought several from Japan but have never used them yet.� I'll look closer the next time I'm digging around.
> > > Lyle
> > > > Miles
> > > > --- In
Jerry A
Post by Jerry A »
http://neolife.cart.fc2.com/?ca=1
also has a parts for our cars.
There is one more site that specializes in racing parts that i cannot find at the moment but they have neat stuff like fiberglass hoods and fenders for the N.
Fri, 5/13/11, twincarb600
> From: twincarb600
> Date: Friday, May 13, 2011, 2:13 AM
> > From: twincarb600
> > > From: twincarb600
> > > > Lyle
> > > > --- In
> > > > > Miles
> > > > > --- In
pommecoing
Post by pommecoing »
> Hello,
This site is fantastic. Not only for timing items. What did you do exactly to buy on this site ? What do you call a broker ? Sorry for my poor english.
Thank you a lot : Pierre
