Timing rollers
Steve A
Timing rollers
Post by Steve A »
Does anyone need lower and upper timing chain rollers and primary
I have a set of them and they are great quality needle bearing in the lower one
bronse others let me know if interested I will pass email to you
Re: Timing rollers Material?
Post by feltonminicycle »
I made and tested rollers made of Delrin (Acetal Plastic) 10 years ago and the guide roller could not hold the temperature. I installed and removed the melted roller myself from a customer's car.
What is the material in these rollers shown?
Post by Lyle »
Like Miles I am wondering what the material is?
Delrin and most plastics will not take the heat and pressures of a high rev timing chain.
Some nylons have been used on water cooled engines, but an air cooled engine is running much higher temp's.
It would be great if you found a material that will work.
Any info or test info would be useful if you want to sell these.
Japan was selling rollers, but not sure how they held up to hours of use.
twincarb600
Post by twincarb600 »
The rollers from Japan I think are nylon for the bottom and steel for the top roller. The ones from Japan use ball bearing and not bushings. I have bought several from Japan but have never used them yet. I'll look closer the next time I'm digging around.
> Lyle
> > Miles
steve allen
Post by steve allen »
Im not selling these heres what he said when I ask
we have sold hundreds of these rollers for S600 / S800 and N600 / Z600 cars. They are made from a company working for Ferrari.
Wed, 5/11/11, Lyle
> From: Lyle
> Subject: [2cylinderhondas] Re: Timing rollers Material?
> Date: Wednesday, May 11, 2011, 1:43 AM
> Lyle
> > Miles
Jerry A
Post by Jerry A »
Correct, the Japanese units use nylon with ball bearings for the tensioner (toothed) wheel and what looks like machined aluminum with either bushing or roller bearing depending on which one you want. I am interested in his prices as units from Japan are about $120 each by the time they make it to your door.(depending on currency exchange rate of course). www.auto-spot.net is one of the Japanese suppliers.
Wed, 5/11/11, twincarb600
> From: twincarb600
> Date: Wednesday, May 11, 2011, 3:12 AM
> > Lyle
> > > Miles
Kevin Lister
Post by Kevin Lister »
Am I understanding this this correctly?
Is there a source for the chain rollers in the Honda 600 engines? The large one and the small one on the tensioner?
How about the slipper?
kev
Wed, 5/11/11, steve allen
Subject: Re: [2cylinderhondas] Re: Timing rollers Material?
Date: Wednesday, May 11, 2011, 6:47 AM
Wed, 5/11/11, Lyle
> From: Lyle
> Lyle
> > Miles
> > > I have a set of them and they are great quality needle bearing in the lower one > > > bronse others let me know if interested I will pass email to you
steve allen
No slipper primary tensioner
Wed, 5/11/11, Kevin Lister
> From: Kevin Lister
> Date: Wednesday, May 11, 2011, 5:51 PM
> kev
> --- On
> > From: steve allen
> > To: 2cylinderhondas@yahoogroups.com
> > --- On
> > Wed, 5/11/11, Lyle
> > > From: Lyle
> > > Lyle
> > > > Miles
> > > > --- In
> > > > > I have a set of them and they are great quality needle bearing in the lower one > > > > > bronse others let me know if interested I will pass email to you
twincarb600
I have some of these from Auto-Spot. The upper roller is made out of steel with 1 bearing machined into it. The lower roller has 2 ball bearings and nylon. I never purchased the drive chain roller. I think when I got mine they didn't offer the them yet.
> --- On Wed, 5/11/11, twincarb600 wrote:
> From: twincarb600
> > Lyle
> > > Miles
twincarb600
I just uploaded a picture of the upper roller. Look in the Misc photo folder.
> > From: twincarb600
> > > Lyle
> > > > Miles
> > > > --- In
