Fwd: [anzhonda600owners] Air Intake and Cooling Fan
Re: Air Intake and Cooling Fan
Post by Eric Geiger »
If you have a GPS do a top speed run with that.   I'm really impressed by your speeds and would love to see it on a GPS if possible as well.  Ill do a run this weekend on a GPS and post results
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX phone
XXX-XXX-XXXX fax
XXX-XXX-XXXX mobile
egeiger@...
www.prgnocturne.com
On Jun 11, 2013, at 10:29 PM, "Gabriel Garcia Diaz" wrote:
www.facebook.com/TheBenbrookHondaZ
you can see the pictures I've taken here. You don't have to believe me. I don't need approval just wanted to share that intake and exhaust upgrades could be done inexpensively. I think removing that belt driven fan for the electric radiator fan has been the best improvement to acceleration. I'll take a picture of the Infrared thermometer next time so you guys can see the temp off the block. I use my Z on the weekends and an electric mountain bike as a daily commuter. The bike is capable of 35mph on electric power alone. But I don't normally keep it at top speed as that greatly diminishes range of the Lithium battery. There's a video of a Z600 on youtube that was converted to electric drive. That is the reason I bought the Z in the first place, but batteries are still too expensive. In the meantime I'll enjoy the almost 40mpg I'm getting from the 2cyl engine.
Gabe
On Jun 11, 2013, at 20:03, Mark P Hatten wrote:
> Now you guys make me want to test mine out.  Just great !
> Watch for me on "Super Speeders" or, more likely..... in " jail "
> https://www.youtube.com/watch?v=l2anDmZjtF8
> www.mphspecialties.com
> craft59@...
> Date: Wed, 12 Jun 2013 00:40:32 +0000
> Subject: [anzhonda600owners] Re: Air Intake and Cooling Fan
> Did a high speed run today! I have a stock 1972 coupe restored and rebuilt as close to original as possible. Test run was on level ground, no wind, stock tires 30psi F, 25psi R. Accelerated to 6,200 in 3 gears (not too exciting) then > waited for about 35 seconds to see a top speed of 78-79mph and 6,300rpms. Held it wide open and it wouldn't go any faster. I have been racing for years so I love calculating gear ratio's and tire diameters.
> Stock tires 19.1" in diameter = 60"/rev.
> 12.45mph/1,000rpm
> Total gear ratio 4.60:1
> Engine 4,850 at 60mph, axle 1,050rpm.
> So 95mph = 7,630rpm
> That is a 22% increase in speed/power.
> Sorry but changing the air filter and a muffler is not going to get that increase.
> Prove me wrong.
> Lyle
> , Eric Geiger wrote:
> > Thats what i was thinking. I've had mine up to 75 on the speedo on the freeway and i was redlined at 6k. i couldn't imagine taking it any further than the 6k in 4th gear. i haven't compared my speedo to a GPS yet but plan on doing so next week.
> > look forward to seeing a vid.
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@...
> www.prgnocturne.com
> http://www.prgnocturne.com/
> > On Jun 9, 2013, at 12:52 AM, Mark P Hatten wrote:
> > 75 mph is close or past redline in 4th depending on tire size.
> > 95 mph has to be roughly 9000 rpm in 4th
> > I dunno for sure , but doubtful
> http://www.mphspecialties.com/
> > From: egeiger@...
> > Date: Sun, 9 Jun 2013 01:04:40 +0000
> > Subject: Re: [anzhonda600owners] Air Intake and Cooling Fan
> > is that 95mph on your speedometer or a GPS?
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@...
> www.prgnocturne.com
> > On Jun 8, 2013, at 7:53 PM, Bill wrote:
> > Hi Gabriel;
> > How many rpm's are you turning at 95 mph?
> > [mailto:
> On Behalf Of Gabriel Garcia Diaz
> > Sent: Saturday, June 08, 2013 5:09 PM
> > To: Z600 Group
> > Subject: Fwd: [anzhonda600owners] Air Intake and Cooling Fan
> > Here's the link to the video
> http://youtu.be/qhg2iAWbIAw
> > Sent from my iPhone
> > Begin forwarded message:
> > From: Gabriel Garcia Diaz >
> > Date: June 8, 2013, 7:07:58 PM CDT
> > To: Z600 Group anzhonda600owners@yahoogroups.com
> > Subject: [anzhonda600owners] Air Intake and Cooling Fan
> > Reply-To:
> > Since it's been the topic of choice I want to share what I've done to my Z600. My intake filter cost me around $20. Another $20 for the electric fan, and $5 for the aluminum bar stock I used to make the bracket to hold the fan in place. The filter with a > less restrictive exhaust has gained me a top speed of 95mph. The electric fan lowered the temperature from 250 to 190 on the aluminum head verified by an infrared thermometer. Let me know what you guys think.
> > Sent from my iPhone
Mark P Hatten
Post by Mark P Hatten »
I've improved my 0--60 mph time. I can now do 0-63 mph in the same 1/4 mile shifting @ 6200 rpm.  Synthetic oil gave me almost 2 more MPH.   GPS Video @ 11.
Post by Lyle »
Hi Bill, your right the cam, point float, and just lack of HP to push the weight/frontal area any faster. I do have my electronic ignition, so no point float. Living in Florida we have really flat roads and I tested both directions. 78mph one way about 80 the other way. This is using the Honda speedometer and tach as indicated, probably not true readings. This matches what the road tests back in 1972 wrote. On a down hill run probably faster but the crank and timing chain is so weak I don't like to push it past 6,000 rpm's under load. 4-5mph is a lot of gain when we only have 36HP to start with.
Gabriel did some simple and clever modifications I like them. I just don't think 95mph and over 7,600 rpm's is possible with a stock motor.
We should ask the racing Honda guy, he runs a heavily modified Honda Z at the salt flats. What is his name?
So when Mark does his "high speed" run it has to be on level ground, GPS and video recorded.
Looking forward to it.
, "Bill" wrote:
> Hi Lyle;
> Good test, I had one of mine up to 7K rpm's and then went past the power
> curve (the points floated) the engine stopped running until it got to about
> 5500 rpm's and started back up. I did this three times and had the same
> results. The gears were like new, the pistons were .50 over the rockers and
> cam and all internals were like new or measured to new spec. But I was
> running mag rims 5in wide which brought it about 12 pounds lighter in
> unsprung weight. All else was stock.
] On Behalf Of Lyle
> Sent: Tuesday, June 11, 2013 5:41 PM
> exciting) then waited for about 35 seconds to see a top speed of 78-79mph
> 12.45mph/1,000rpm
> So 95mph = 7,630rpm
> increase.
> Prove me wrong.
> Lyle
> , Eric Geiger
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@
> > www.mphspecialties.com > To:
> > From: egeiger@
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@
> > www.prgnocturne.com > On Jun 8, 2013, at 7:53 PM, Bill wrote:
> > Hi Gabriel;
> ] On Behalf Of Gabriel Garcia
> Diaz
> > To: Z600 Group
> > Sent from my iPhone
> > To: Z600 Group
> > Reply-To:
> in place. The filter with a less restrictive exhaust has gained me a top
> guys think.
> > Sent from my iPhone
1/4 mile time 0-60
Post by Lyle »
Hi Mark I love your video's. But, it looks like you rolled your 1/4 mile start! You should run it again, straight line 1/4 mile. Leave at about 3,000rpm a little tire squeak and shift at about 6,200-6,300. I think you could get close to 60mph and 20 seconds. That's about what I can do with my stock Coupe.
You have plenty of time to hit the stop watch, look at the speedometer and the tach, change the radio station and check the camera.
Or take it to your local drag racing track, the crowd would love it!
> From: craft59@...
> Did a high speed run today! I have a stock 1972 coupe restored and rebuilt as close to original as possible. Test run was on level ground, no wind, stock tires 30psi F, 25psi R. Accelerated to 6,200 in 3 gears (not too exciting) then waited for about 35 seconds to see a top speed of 78-79mph and 6,300rpms. Held it wide open and it wouldn't go any faster. I have been racing for years so I love calculating gear ratio's and tire diameters.
> 12.45mph/1,000rpm
> So 95mph = 7,630rpm
> Prove me wrong.
> Lyle
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@
> From: egeiger@
> > Eric J. Geiger
> > PRG Nocturne
> > XXX-XXX-XXXX phone
> > XXX-XXX-XXXX fax
> > XXX-XXX-XXXX mobile
> > egeiger@
> > Hi Gabriel;
[mailto:
] On Behalf Of Gabriel Garcia Diaz
> > To: Z600 Group
> > Sent from my iPhone
> > To: Z600 Group > Subject: [anzhonda600owners] Air Intake and Cooling Fan
> > Reply-To:
> Since it's been the topic of choice I want to share what I've done to my Z600. My intake filter cost me around $20. Another $20 for the electric fan, and $5 for the aluminum bar stock I used to make the bracket to hold the fan in place. The filter with a less restrictive exhaust has gained me a top speed of 95mph. The electric fan lowered the temperature from 250 to 190 on the aluminum head verified by an infrared thermometer. Let me know what you guys think.
> > Sent from my iPhone
Mark P Hatten
Hi Lyle What do you use for electronic ignition?
Mark
