Not only is the spark now much, much Hotter, but more importantly the points are now relieved of handling the relatively high coil current and only have to deal with a very small trigger current which allows them to function almost indefinitely at least from an electrical point of view.
Just for reference keep in mind that the Honda is a simultaneous fire engine ie both plugs fire together at the same time. I ended up using an "ACCEL 140406BK Dual Fire Black Super Coil" (a performance upgrade for Harley-Davidson which also happens to be simultaneous double fire).
So far, this arrangement seems to be functioning flawlessly. Just be sure to retime the engine on the "Hot" side to compensate for any possible delay in the electronics. I didn't experience any, but better to be sure.
Good luck if you decide to give it a try.
> On August 13, 2019 at 1:05 AM "tgm_enterprizes@... [anzhonda600owners]" wrote:
> I have a pertronix igniter that is on a 600 advance plate. It’s 1/2 the issue, the other piece to this is on the rotor. It has to be machined in order to mount the round piece that I think contains the magnets.
> I only have one and I did a rough estimate of what I would need to get and if the pertronix igniter is used, it would end up being about $175. BUT, the system you really want is the pertronix igniter II (protected against you wiring it wrong and some other things) of course it’s more expensive, but if I was to make this, I would have to use the version 2 since I don’t want to deal with someone blowing up the module and saying it was my fault.
> I have 2 MSD 6AL boxes, how do you wire them up for the 600’s?
> P.s. on my website, you can scroll through the pictures I put on there and you will see that I use Accel super coil as my coil. It has 2 outputs and has the hottest spark of any coil you can get. It’s like 80,000volts or more, (I am old and forget). It also had a gigantic effect on the engine starting and I haven’t had any high RPM miss since I put it on. I put it right where the old coil was (see picture).
> Richard
> Honda600Performance.com
