Sun, 8/15/10, lyletrudell
> From: lyletrudell
> Subject: [anzhonda600owners] Re: Parts for Honda 600's
> Date: Sunday, August 15, 2010, 8:00 PM
> Good info.
> So if we shorten the sleeve, or open up the cup washers ID then they will work.
> Simple modification and off the shelf parts.
> Lyle
> , WoodWizard 33 wrote:
> > The KYBs work !� but......
> > The the upper casing is not tapered like the originals -� though does provide sufficient clearance along side of the the frame (barely) > > Also, there is a metal sleeve inside the shock bottom bushing which protrudes about 1/4" on each side - which the stock version does not have.
> > This leaves just enough room to secure with the lock washer and nut - but without grinding the steel sleeve, there's no room for cupped washers in a stock configuration.
> > .....and thanks Steve !!
> > --- On Sat, 8/14/10, Steven Michelsen wrote:
> > From: Steven Michelsen
> > Subject: Re: [anzhonda600owners] Re: Parts for Honda 600's > > To:
> > Date: Saturday, August 14, 2010, 11:29 AM
> > Oops.� I took down that info and added the KYB shocks as a first listing.� > > � > > I guess I should suggest that the list should only contain parts that an owner has used and has confirmed to work.
> > I will add a comments column for any (brief) notes that need to be passed along.
> > Steve
> > From: lyletrudell
> > Sent: Saturday, August 14, 2010 1:59 AM
> > Sorry Jerry, yes, it was just an example.
> > But, see how desperate we are for parts!!!!
> > If I said, I have NOS suspension parts, I could be selling them for way more than they are worth!
> > That's wrong, and if we sit back and wait, we will be trapped by the people who have the last parts left.
> > Hey, that's OK for people doing a perfect restoration and want all NOS Honda original parts.
> > But, for people who just want to drive their Honda's
> it will suck.
> > This has happened to many vintage cars.
> > Lyle
> , Jerry A wrote:
> > > is that part number just an example? i could not find it listed anywhere online.
> > > --- On Fri, 8/13/10, lyletrudell wrote:
> > > From: lyletrudell
> > > Subject: [anzhonda600owners] Re: Parts for Honda 600's > > > To:
> > > Date: Friday, August 13, 2010, 10:05 PM
> > > Steve, I was thinking about how to organize the parts we need for our Honda's, again.
> > > I think your web site is the best place!
http://www.honda600coupe.com/index.html
> > > His site was the reason I got into the Honda's, good pictures, links, info and well organized! Yahoo is a good place to post questions, but we need our own place for information!
> > > Steve, how about a list of parts we have found that will work.
> > > Something simple and easy to update, maybe a word document?
> > > Honda Coupe Front Strut assembly
> > > Vickers#24377-1969 Saab-AutoZone-$43.
> > > Then if a member finds another part, reproduces a part or finds a new source that is better or cheaper we send the info to Steve.
> > > We all need parts, this could help us all, if we all help.
> > > Lyle
> , "lyletrudell" wrote:
> > > > Jerry, parts most people will need to keep their cars running.
> > > > Rubber:
> > *Air cleaner bellows.
> > > > *Intake manifold.
> > > > *Cam housing seal
> > > > *cam chain tensioner rubber wheels and slider.
> > > > *primary tensioner wheel and rubber oiler thing.
> > > > *Gear shift bellows.
> > > > *Steering rack bellows.
> > > > *Tie rod bellows and boots.
> > > > *Ball joint boots
> > > > *Stabilizer bushings.
> > > > *steering pinion dust boot.
> > > > *Brake booster bellows
> > > > Misc:
> > > > *Tie rod ends.
> > > > *Ball joints.
> > > > *Front struts
> > > > *Clutch friction disk and spring
> > > > *Rocker arm
> shafts.
> > > > --- In
> , Jerry A wrote:
> > > > > what parts are unobtainable? I have been ordering parts I need from japan but have passed up on a lot of parts because I didn't need them but if I had a list of parts that we cannot touch I could snag them up when I find them
> > > > > On Wed Aug 11th, 2010 5:02 PM ADT lyletrudell wrote:
> > > > > >Dale, didn't want to mislead, it's not a Gold mine! Just some parts from an independent auto parts store that closed a few years > ago.
> > > > > >Hey, anything we can find is good.
> > > > > >I will get the stuff this weekend, its mixed with a bunch of parts so I don't know what is 600 parts yet.
> > > > > >I was just excited to find anything related to a 600!
> > > > > >Lyle
> > > > > >--- In
> , goinhm@ wrote:
> > > > > >> Hi Lyle,
> > > > > >> That was a good find. Let us know what
> you have for sale after you
> > > > > >> sort out what is extra. I never would have suspected that Florida would be a
> > > > > >> gold mine for 600 parts.
> > > > > >> Dale
> > > > > >> I found a couple small local suppliers that have a small amount of Honda
> > > > > >> 600 parts.
> > > > > >> NOS and some new.
> > > > > >> The stuff looks to be in nice shape.
> > > > > >> Mostly:
> > > > > >> *Brake
> > > > > >> *Ignition
> > > > > >> *filters
> > > > > >> *CV boot
> kits
> > > > > >> I will buy the inventory so it won't be scrapped.
> > > > > >> Like I said before, I only plan on having one Honda.
> > > > > >> I will keep some parts for backup and sell the rest cheap (or trade) to
> > > > > >> friendly Honda owners!
> > > > > >> I also have a great small local industrial supplier (Motorcycle buddy) I
> > > > > >> use for my shop. I can get new Viton and Buna O-rings and seals really cheap
> > > > > >> through them. They got me "almost" all the seals/o-rings for my carb,
> > > > > >> engine & transaxle. Still searching for a couple unusual size seals.
> > > > > >> We have quite a few owners, find a part we can
> use.
> > > > > >> Tie rod ends, ball joints, rubber boots for them....
> > > > > >> Lyle
