Radios - 8 Tracks
timk11
Radios - 8 Tracks
Post by timk11 »
The Honda 600's came with either AM or AM/FM Radios. Never 4 or 8
Tracks or cassette decks. Coupe's problem is that the original radio
was so tiny, not much else will fit in that space. I guess if you
have a rodknock a radio is a good thing. But without any engine
sensors:temp gauge, oil pressure gauge, low oil warning light etc a
stereo could muffle sounds emitting from your car which could in
effect be helpful in diagnosing repairs. Like the sound of scraping
metal on metal just before your fan pulley cuts thru your clutch
cable. The sound of wheel bearings before major failure causing you
to replace the knuckle & driveshaft instead of just the bearings
because when the bearings wear that bad the movement can tear up the
knuckle & driveshaft. Drive On - Be Happy !
alarconlujan
Re: Radios - 8 Tracks
Post by alarconlujan »
Hi z600,
And wich make or brand were the original coupe radios from?
Thank you.
P.S.: Fan pulley may cut clucth line�?
