I have decided to take on the project of scanning in the contents of the " Honda Z360/600 Coupe shop manual" and make them available as a pdf file to those interested in such things. You can print them out after scanning.
Here is chapter 2, "inspection and maintenance" part 1 and part 2.
Each of the two files linked to below are about 2.5 megabytes, so downloading may take a bit.
To get the files, right-click on the link and select SAVE TARGET AS from the drop down menu. I do not recommend just clicking on it, as it will open the file in your browser and you probably won't be able to save it after it's open.
http://www.1978mgmidget.com/Honda_600_C ... part_1.pdf
http://www.1978mgmidget.com/Honda_600_C ... part_2.pdf
I have no idea when I will get time to do more, so please don't be in a rush to see the rest of the book. I will post when I get more done.
Have fun,
Coupe shop manual
Re: Coupe shop manual
Thanks Steve, got them.
"Honda Z360/600 Coupe shop manual" and make them available as a pdf file to> I have decided to take on the project of scanning in the contents of the
Re: Coupe shop manual - you likey lawsuit??
You will find that manual is still in print and that if you copy and
distribute them you may hear from Helm aka www.helminc.com
