I've broken both the motor mounts in my coupe. (Not that much
horsepower - I think the disc rusted to the shoes.)
Any tricks for getting the new ones in? The grill is currently out,
if that helps at all. Just not sure how I want to lift the motor up a
bit in the car to slide in the new one.
TIA,
Eric
Motor mounts
Nevermind (was Re: Motor mounts)
Looks like both motor mounts are fine. One exhaust header was loose and bouncing around (open independent pipes.)
But there is still some minor problem - I think the disks now have a ridge from the brake pads. Need to put the car on jack stands again and pull the front wheels to check.
> TIA,
> Eric
Re: Nevermind (was Re: Motor mounts)
Lucky for you the rotors come off the car very easily. You can send them
into a machine shop and have them turned or you can do it yourself if you
have a lathe. Let me know if you need information on the minimum allowable
rotor thickness.
rotor thickness.
