I'm sure this has been asked before... What is the largest wheel size
and offset that can be used with an N-600. Am I correct that the lug
nut pattern is 100mm.
Jason,
Wheel size
Re: Wheel size
They are actually 110mm (4x110 is what you'll see online) - and there are some 12" mazda rims that fit. Run low profile tires and they look pretty cool.
(But there also is some debate on the wear it causes on your bearings.)
We found that the rolling resistance (increased) meant that the car couldn't go as fast in the top end. But they look cool . . .
> Jason,
