I have a 72 N600, misses at a steady speed or off the gas, runs fine
if on the gas, dosen't like to idle also. I installed new points,
condenser, plugs, and a used coil. Seems to be carb related, cleaned
carb but still misses. Any info would be helpfull, Thanks. Also can
someone tell me how to change the font on messages so everyone can
read it, Thanks.
Dan McGiveron
Marshfield, WI
Bad Running Sedan
Re: Bad Running Sedan
not sure how long your cars have been sitting, but my 72 coupe had a
similar problem, it was the gas tank that had alot of rust in it,
and kept clogging my carb. I had the gas tank relinned and the car
runs as smooth as ever now.
Hi Dan;
An ignition miss is coming from several areas. Change your wires, go to
the ANZ site and there is an article on how to change the plug wires on the
coil to carbon core. Then if it is still missing, and even though you can't
hear it at high rpm's it is most likely still there. But I will bet it is
the plug wires and the terminals at the end.
