Just to let you know that I've added some photos of the car as it is
right now. Finishing touches still to be done. The reverse gear
engaging problem was quickly fixed. The pin used to join the selector
rod to the gear lever was not push all the way in and was fouling on
the engine casing. Reverse now engages beautifully! Have now also
replaced the front to rear brake line as it had a split. Bleeding the
brakes tonight. New windshield washer tubing to be installed tonight
with new bonnet jet and interior switch/pump. Have also found a good
condition bag for under the hood.
Here's the link
http://www.geocities.com/kiwi_aircooled ... iary7.html
enjoy.
James
