OK, I give up - how do you remove the rear seat on a 600 coupe. On my
other vintage cars you push the seat cushion back, then lift up. My
attempts at getting the bottom cushion out of my car have met with
nothing but frustration so far - all I want to do is replace the fuel
filter.
Thanks in advance for your help.
Ray
Remove rear seat
Re: Remove rear seat
10mm bolt in back of seat cushion bottom holds in the back seat, then
tilt it forward to remove it. Wait until you try to remove the 6mm
phillips headed screws to replace the filter!!!!!!!!! - vice grips
probably.
probably.
Grab the back center and lift forward, the front hooks are an L shape
pointing to the front of the car. When the Seat is vertical lift it off
and out of the car.
and out of the car.
Vice grips? I had to use a drill and re-tap the holes! But that was just a small amount of rust. lol
> 10mm bolt in back of seat cushion bottom holds in the back seat, then > tilt it forward to remove it. Wait until you try to remove the 6mm > phillips headed screws to replace the filter!!!!!!!!! - vice grips > probably.
Do you Yahoo!?
New and Improved Yahoo! Mail
- 100MB free storage!
