Any two cylinder motorycycle coil will work. I used the accel coil
without problems.
David
motorcycle coil
Re: motorcycle coil
Does 12 or 6v make a difference?>Any two cylinder motorycycle coil will work. I used the accel coil
>without problems.
>David
Mike Gladu, Cycling Photojournalist, Infinite HangTime Photography
Honda '82 CB900F, '84 XR200R, '70/'71/'80/'81/'82/'83 C70 Passport
Honda '86 VT500C, '97 Dream 50, Husqvarna '84 510TE, BMW '74 R60/5
Passport/C70 info: http://www.velodrome.com/HondaC70/HondaC70.html
dustyspath
Re: motorcycle coil
Yes, I think a 6v coil on a 12v system yields a much hotter spark. :)
> >Any two cylinder motorycycle coil will work. I used the accel coil > >without problems.
> >David
> ------------------------------------------------------------------ > Mike Gladu, Cycling Photojournalist, Infinite HangTime Photography > Honda '82 CB900F, '84 XR200R, '70/'71/'80/'81/'82/'83 C70 Passport > Honda '86 VT500C, '97 Dream 50, Husqvarna '84 510TE, BMW '74 R60/5 > Passport/C70 info:
Do you Yahoo!?
Yahoo! Mail
- You care about security. So do we.
Re: motorcycle coil
yes, but before you go charging off to get a new coil check out the repair
to your coil on the ANZhonda600owners page. Look in the photo album section
under coil repair. Many of the coils only need new wires. Cut the wires
out and do a continuity check between the two barbs at the bottom of the
wires. (You can check them by going to the bottom of the wire next to the
coil with your meter) If it's the blue wire the same can be done here.
If your not sure, send it to me and I will check it out for free.
Send it to:
Bill Colford
7518 Westbrook Ave.
San Diego, CA. 92139
Along with $5.00 to return postage (priority mail) most destinations in the
USA.
And, if you just want to send it to me, I will send back a "Made in Japan"
engine compartment decal.
Send it to:
Bill Colford
7518 Westbrook Ave.
USA.
robertprentice55
Re: motorcycle coil
It will also FRY your points in a very short time, as it requires more current to fire it!!!
Larry
Marshall Montchalin wrote:
Larry
> Yes, I think a 6v coil on a 12v system yields a much hotter > spark. :)
> Marshall
> Mike Gladu
> > >Any
> > >without problems.
> > >David
> > Passport/C70 info:
> Do you Yahoo!?
> Yahoo!
