What kind of lug nuts are we using on mazda wheels fitted to a Z600 or N600? Will the stock lug nuts work without problems?
Thanks
Mike OConnor
Re: Digest Number 861
robertprentice55
Stock Mazda nuts are a 12mm x 1.25 ... it's necessary to either make sleeves for the Honda studs, or have someone replace the stock Honda studs with a set of the larger 12mm studs, like I did ... I took 2 drums and 2 front hub flanges, and enlarged the existing stud mounting holes to accept the splines of the 12mm studs ... since the bolt pattern is the same, it was an easy conversion, once I found studs with the correct length!!! I still have another set!!
Larry Cooley
tmoc1990@... wrote:
Larry Cooley
tmoc1990@... wrote:
> What kind of lug nuts are we using on mazda wheels fitted to a > Z600 or N600? Will the stock lug nuts work without problems?
> Thanks
> Mike OConnor
