Air Conditioning
Air Conditioning
Hi, does anyone know of a company that manufactures aftermarket A/C
units for the Honda 600?
xjacksonx3
Re: Air Conditioning
All Honda 600's, both sedans and coupes came from the factory with 2-60
air conditioning!! ... any other effort is futile!!
( 2 windows open @ 60 mph!!! )
C'Ya,
Larry
C'Ya,
Larry
Do you think a Honda 600 would actually still move forward with
additional drag of an A/C compressor? Plus there is no place to mount
the pump around the engine area.
I had always fancied installing a home air conditioner (window mount)
in the trunk of a sedan. It's 110 volt but these days voltage
inverters are pretty cheap.
At 6:19 AM +0000 6/7/05, Miles Chappell wrote:
powered (so it will function when the engine is not running).
Maybe the compressor guts can be converted to Honda use...
Mike G.
Mike Gladu, Cycling Photojournalist, Infinite HangTime Photography
Honda '82 CB900F, '84 XR200R, '70/'71/'80/'81/'82/'83 C70 Passport
Honda '86 VT500C, '97 Dream 50, Husqvarna '84 510TE, BMW '74 R60/5
Passport/C70 info: http://www.velodrome.com/HondaC70/HondaC70.html
The air conditioning compressor in a Toyota Prius is electric motor>Do you think a Honda 600 would actually still move forward with
>Miles
Mike G.
driftgtrskyline
The reason I asked, is because I have seen units that are completely self contained and mount under the dash for old hotrods, and was just wondering if there were anything like that for the 600.
Mike Gladu wrote:
Find restaurants, movies, travel & more fun for the weekend. Check it out!
Mike Gladu wrote:
Discover Yahoo!> At 6:19 AM +0000 6/7/05, Miles Chappell wrote:
> >Do you think a Honda 600 would actually still move forward with > >additional drag of an A/C compressor? Plus there is no place to mount > >the pump around the engine area.
> >I had always fancied installing a home air conditioner (window mount) > >in the trunk of a sedan. It's 110 volt but these days voltage > >inverters are pretty cheap.
> >Miles
> The air conditioning compressor in a Toyota Prius is electric motor > powered (so it will function when the engine is not running).
> Mike G.
> ------------------------------------------------------------------ > Mike Gladu, Cycling Photojournalist, Infinite HangTime Photography > Honda '82 CB900F, '84 XR200R, '70/'71/'80/'81/'82/'83 C70 > Passport > Honda '86 VT500C, '97 Dream 50, Husqvarna '84 510TE, BMW '74 R60/5 > Passport/C70 info:
At 8:16 AM -0700 6/7/05, Troy Pickle wrote:
Mike G.
Do they have internal compressors, or are they 'swamp coolers'.>The reason I asked, is because I have seen units that are
Mike G.
Very good question about compressors or swamp coolers.
I can't imagine one that would work with a compressor,but I do
have a swamp cooler type on my VW bus and it runs only off the
battery.
We also have a 9 gallon tank in the back and an electric pump that is
all hooked up with the cooler and all runs off the battery,
So far no problems, and no it doesn't run the battery down either,.
The only problem with swamp cooling is you do need a *dry heat*
conditions for it to work efectively.
IF your in part of the country with lots of humid weather the
2-60 air conditioning is the way to go.
If my hubby ever gets my 600 working again, (which is a matter of
working on it) I am considering a smaller version of what I have on
my bus.
Tricia
- In 2cylinderhondas@yahoogroups.com, "Troy"
battery.
my bus.
Tricia
driftgtrskyline
They have internal compressors, the only thing you have to really install is the condenser, but there again is the issue of having room.
Mike Gladu wrote:
Get on-the-go sports scores, stock quotes, news & more. Check it out!
Mike Gladu wrote:
Discover Yahoo!> At 8:16 AM -0700 6/7/05, Troy Pickle wrote:
> >The reason I asked, is because I have seen units that are > >completely self contained and mount under the dash for old hotrods, > >and was just wondering if there were anything like that for the 600.
> Mike G.
Joseph Corsinita
if you want a swamp coolers I'll sale you my Vintage Car Air Conditioner for $200.00 + shipping
Jose
In a message dated 6/8/2005 12:37:47 PM Eastern Daylight Time, bullriderinwranglers@... writes:
Jose
> Mike Gladu
> > Mike G.
Air Conditioning
I think I found a solution to the A/C questions for the 600, check out
www.vintageair.com , go to cataloge, and then to Mini Slimline Unit, I
think the dimentions will work for the honda. It is a complete unit,
condensor is inside the unit and has a drain kit with it, Dimensions
are approx. 20" wide, 5 1/4" tall, and 12" deep.
