FW: parts needed
FW: parts needed
Post by Lyle »
Any Honda 600 sedan bodys around Kristi Werners area? Read the thread
below, it seems a tree fell on her car and she now needs a body.
JN
Re: FW: parts needed
Post by JN »
Bill, Kristi
I live in Yakima and I've got a couple of cars that I am restoring. I spoke with Miles and he mentioned a couple of guys in Washougal (down around Pasco/Kennewick) who do engine work and have quite a few vehicles on hand that they use for parts. This might be an option. Master Miles might be able to help with specific contact information.
Myke Holford
Yakima Washington
> "Bill Colford"
> Reply-To:
> , > Subject:
> [2cylinderhondas] FW: parts needed
> Date:
> Mon, 9 Jan 2006 22:55:53 -0800
> Any Honda 600 sedan bodys around Kristi Werners area?  Read the thread > below, it seems a tree fell on her car and she now needs a body.
> From: kristi werner [mailto:kristiandrob@...]
> Sent: Monday, January 09, 2006 9:43 AM
> To: billmyong@...
> Subject: RE: parts needed
> I am in Bremerton Washington, close to Seattle and Tacoma
> >From: "Bill Colford"
> >To: "kristi werner"
> >Subject: RE: parts
> needed
> >Date: Sun, 8 Jan 2006 10:10:36 -0800
> >Sorry to hear that, where are you located?
> >Bill
> >Sent: Sunday, January 08, 2006 6:19 AM
> >To: billmyong@...
> >well. a tree fell on my little car.  so now I need a whole new body.  Do > >you > >have any sugestions?
> > >To: "kristi werner"
> > >Date: Sun, 23 Oct 2005 22:46:29 -0700
> > >Hi Kristi;
> > >      I haven't heard from your mechanic on parts he needs.  Are you > folks > >doing > > >ok?
> > >Bill
> > >From: Bill Colford [mailto:billmyong@...]
> > >Sent: Tuesday, October 11, 2005 1:26 AM
> > >To: kristi werner
> > >XXX-XXX-XXXX
> > >I normally get home at 7pm.
> > >Bill
> > >Sent: Monday, October 10, 2005 1:41 PM
> > >To: billmyong@...
> > >My friend Garth has these 2 cars and I am buying the N600 from Him.  He > >is > > >an aircraft mechanic and he purchased these cars from a guy in > Wa.  He is > > >restoring them and these are the parts he needs for both cars.  Mine just > > >needs the calipers.  I believe what he did was buy 4 cars and used 2 of > > >them > > >for parts cars.  I think it might be helpful if you two could talk.  Can > >I > > >get your phone number?   Thank You, Kristi Werner
> > > >To: "kristi werner"
> > > >Date: Mon, 10 Oct 2005 03:25:13 -0700
> > > >Hi Kristi;
> > > >      My name is Bill Colford, I maintain the Honda 600 Owners listing for > > > >all Honda 600 owners all over the world and I try to help where I can.
> > >      There are a few things you should know when buying parts for your > > > >Honda 600.  First, you need to know what the chassis, engine and date > >of > > > >manufacture numbers are for your AN600.  Their are 4 different > > > >configurations of the Sedan but the numbers are sequential for the > >whole > > > >series run from 1969-1972.  Honda made changes and without the numbers > >it > > > >can be a real problem to fix your car correctly.  However, if your car > > >was > > > >updated ("later year of manufacture" parts were put on it by one of the > > > >previous owners) then the puzzle takes on a different picture.
> > > >      Second, if your sedan was updated, then that needs to be figured out
> >and if I or someone else (even Honda) want to order or send parts to > >you, > > > >the subject "Will they fit" comes into play.
> > > >      Third, do you have the Honda Owners, Parts and Shop manuals for your > > > >year of Sedan? There are two of each, the Honda 600 owners and parts > > > >manuals > > > >are as stated for one or the other car and are specific to cars > >Imported > > > >into America.  The shop manuals are a bit more confusing, the 1st is a > > > >large > > > >manual commonly known as the Sedan manual it covers the first > > >configuration > > > >of Honda N600 for all countries Honda made them for. The 2nd manual is > > > >commonly known as the Coupe manual.  It supplements the Sedan manual > >but
> >only covers portions of the engine carburetion and electricals used on > > >both > > > >the Sedan and Coupe models built after April of 1971.  This is where > >the > > > >Parts manual is necessary, it includes the chassis/engine number the > >part > > > >fits based on the engine and chassis number in your car.
> > > >      Case in point; the exhaust on a 10 motor is different than for a 15 > > > >motor (engine numbering system starts with (early) N600e-10- - - - - > >or > > > >N600e-15- - - - - for the sedan and N600e- 25- - - - - for all coupe > > >motors > > > >which could also have been placed in your car), however either could be > > > >adapted to your car with the right parts and knowledge to tell the
> >difference.
> > > >      Kristi, if you have gotten this far and not fallen off your chair > > > >yet then your probably wondering why do I need to know all this stuff > > >for?
> > > >Well, the simple reason is because I am not looking at your car, or I > > >would > > > >be finding these things out for you and looking them up in my books.
> > > >      So, before we get started; I have the cam chain that fits all Honda > > > >600 engines, I also make the Head gasket for all Honda 600 engines > >along > > > >with the Cylinder Base and Cam box gaskets.  Price for the Cam Chain is > > > >$65.00, Head Gasket $36.00 and $25.00 for the other gaskets + shipping, > > > >which depends on what you > have.  Total $126.00 + shipping.  I send > > > >everything Priority Mail so the most should be $9.00 which is flat rate > >+ > > > >delivery confirmation.
> > > >      But, I have to ask, what happened to cause you to need these parts?
> > > >Regards
> > > >Bill
> > > >Sent: Sunday, October 09, 2005 8:45 PM
> > > >To: 600miles@...; tmoc1990@...; BillMyong@...
> > > >Subject: parts needed
> > > >Hello, I am on a quest for parts for 2 cars.  #1  1971 N600 > calipers > > >for > > > >the front brakes and   #2  a timing chain system, and gaskets for the > > > >cylinder base, head, valve cover, and exhaust for a 71/71 sedan.  can > >you > > > >help me?
> > > >Don't just search. Find. Check out the new MSN Search!
> http://search.msn.click-url.com/go/onm0 ... direct/01/
> > >Is your PC infected? Get a FREE online computer virus scan from McAfee� > > >Security.
> http://clinic.mcafee.com/clinic/ibuy/ca ... p?cid=3963
> >FREE pop-up blocking with the new MSN Toolbar � get it now!
> http://toolbar.msn.click-url.com/go/onm ... direct/01/
> On the road to retirement? Check out MSN Life Events for advice on how to > get there!
> http://lifeevents.msn.com/category.aspx?cid=Retirement
