bad brake booster in 71 sedan?
dana
Post by dana »
Here is what I have happening:
1. I have to refill the brake fluid about 1 time per month. No brake
leaks on any wheels or master cylinder visible.
2. when I push on the brake, the engine speeds up slightly, when I
let off, it drops back down.
since I rebuilt the back cylinders and bled the fronts, I am making
the assumption that the vacuum booster is leaking when I press on
the brakes. Anyone have an opinion?
here is the real question: what happens if I plug off the vacuum
line, how bad will the brakes get? Does anyone have any idea what I
am likely to find if I dismantle the booster? if the rubber has a
hole in it, can I use something like you patch bike tires (with the
vulcanizing step) to fix it? Or will it be melted and not be
reassemblable (pardon the new word)?
I also figure its contaminating the engine oil as it is probably
getting sucked out. But with a refill per month, it cannot be real
bad (thats maybe 2 or 3 oz per month that is disappearing).
If I block the vacuum line off, will the master cylinder still have
a leak or will it stop since it will no longer be subjected to a
vacuum?
Richard
Re: bad brake booster in 71 sedan?
Post by Steve »
I rebuild brake boosters. You can attempt to fix yours but there are
no parts, I don't even have parts anymore. The rear seal has leaked
into the canister, likely your large diaphragm has become distorted.
After awhile fluid will get sucked into the engine.
The last price I charged to do a booster was $350.00. You can re
reroute your brake line directly to the master cylinder and
disconnect the vac line. I tried to get seals made but there was a
500 piece minimum per seal type with aprox $5000 charge. I did have
the smaller pistons remade and found a 9/16" seal to sub for the end
seal and have done some other things, but without the other large
diaphragms which actually do the work, it's a worthless effort.
dawn_and_darrian
Post by dawn_and_darrian »
Miles,
Just curious to know if you have toyed with the idea of using a brake
booster from another year civic or cvcc.
I'm unsure if it would fit or not, but it might be worth a try.
Post by Steve »
Brake boosters from civics, like most other cars are mounted directly
to the master cylinder. Not sure how that would work. Would need one
from some other car which is mounted remotely like the Honda 600.
dana
Post by dana »
Message
If I reroute the brake line how bad are the brakes? As it is, they aren't great, but about as good as any 600 I have ever had. I bought the double female coupling yesterday to put the two lines together OR is it just easier to bend the one line after taking it off the booster and putting it in the master cylinder?
I was a little worried about kinking or breaking it.
Richard Morris
> 2cylinderhondas@yahoogroups.com [mailto:2cylinderhondas@yahoogroups.com] > On > Behalf Of > Miles Chappell > Sent:
> Sunday, May 14, 2006 2:02
> [2cylinderhondas] Re: bad brake booster in 71 sedan?
> I
> rebuild brake boosters. You can attempt to fix yours but there are > no > parts, I don't even have parts anymore. The rear seal has leaked > into the > canister, likely your large diaphragm has become distorted.
> After awhile
> master cylinder and
> there was a
> 500 piece minimum per seal type with aprox $5000 charge. I did > have > the smaller pistons remade and found a 9/16" seal to sub for the end
> --- In 2cylinderhondas@yahoogroups.com, "Richard
> Morris"
> > Here is what I
> have happening:
> month. No brake
> visible.
> > 2. when I push on the brake, the engine speeds up slightly, > when I > > let off, it drops back down.
> > since I rebuilt
> > the assumption
> > the brakes.
> melted  and not be
> probably
> > getting sucked out. But with a refill per month, it cannot be > real > > bad (thats maybe 2 or 3 oz per month that is > disappearing).
> > vacuum?
> Richard
Hi Matt;
I looked through my list of owners and didn't see your 71 Sedan listed. If
you could send the Chassis, Engine and date of manufacture I might have a
rebuildable Sedan cast iron booster. The cast iron boosters can still be
rebuilt if (like Miles says) the diaphragm is still good.
G.Bertolin
Post by G.Bertolin »
victoria british sells a remote vacuum booster for a
sunbeam alpine. one line in and one line out.
walt
> mounted directly
> the Honda 600.
, "Matt
> Timion"
> > Miles,
> idea of using a
> brake
> worth a try.
> > From: "Miles Chappell"
> > To: > Sent: Sunday, May 14, 2006 12:01 PM
> > Subject: [2cylinderhondas] Re: bad brake booster
> in 71 sedan?
> yours but there
> are
> rear seal has
> leaked
> has become
> distorted.
> engine.
> $350.00. You can re
> cylinder and
> charge. I did
> have
> seal to sub for the
> end
> worthless effort.
> > > Miles
, "Richard
> Morris"
> time per month. No
> brake
> up slightly, when
> I
> fronts, I am
> making
> plug off the vacuum
> have any idea
> what I
> if the rubber has a
> bike tires (with
> the
> melted and not be
> as it is probably
> month, it cannot be
> real
> disappearing).
> cylinder still
> have
> be subjected to a
> > >> vacuum?
> > >> Richard
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
Do they have a web site?
isettajoe
Post by isettajoe »
The fellow who redid my sedan engine and brakes used a brake master
cylinder from an 83 Civic and scrapped the booster. The unit fits
thru the firewall fine, and only needed some mounting holes
enlarged. It has plenty of stopping power. He has done this on his
2 sedans too.
It sounds like a great mod, did the push rod have to be replaced?
