Giving it a shot, anyone have a gear shift console bracket laying
around? i dont need the console itself but the bracket that relocates
the shifter and what the console screws to. Or maybe if you have the
entire thing for sale.
TIA
Looking for a sedan gear shift console bracket. probably impossible
Re: Looking for a sedan gear shift console bracket. probably imposs
Any more info on the fuel door for the 1972 Honda 600 Sedan? You mentioned you may have a yellow-colored one. Would appreciate info on hinge, etc. Thanks!!
infinkc wrote: Giving it a shot, anyone have a gear shift console bracket laying
TIA
Do you Yahoo!?
Get on board. You're invited to try the new Yahoo! Mail Beta.
TIA
Do you Yahoo!?
tommyjayallen
If you are talking about a console for a sedan, you can make the mounting brackets quite easily. Just bend up some thick sheet metal into "u" shapes. I'm not sure what you mean by the shifter bracket. If you don't have the correct shifter for the console you're kind of screwed. The original shifter will not work in the console.
TIA
Groups are talking. We´re listening. Check out the handy changes to Yahoo! Groups.
TIA
From what the manual shows the shifter looks the same, can anyone
confirm this or post pictures of the differences? the shifter
console bracket in the manual looks like it just relocates the
shifter downwards.
shifter downwards.
tommyjayallen
Although it looks the same It is dimensionaly different. Every part on it is different. I imagine if you are dilligent you could modify a stock unit to make it work. But, be prepared to install and remove it several times. All of the pivot points are different, as are all the component lenghts. If a standard shifter would work it wouldn't have a different part number. Good luck.
infinkc wrote: From what the manual shows the shifter looks the same, can anyone
shifter downwards.
shifter downwards.
No, the shofter shaft is longer.
-----Original Message-----
[mailto:2cylinderhondas@yahoogroups.com]On Behalf Of infinkc
Sent: Monday, July 31, 2006 9:24 AM
Subject: [2cylinderhondas] Re: Looking for a sedan gear shift console
bracket. probably impossible to find :(
shifter downwards.
--- In 2cylinderhondas@yahoogroups.com, Tad Clark
shifter downwards.
mounting brackets quite easily. Just bend up some thick sheet metal> If you are talking about a console for a sedan, you can make the
have a gear shift console bracket laying> infinkc wrote: Giving it a shot, anyone
changes to Yahoo! Groups.> around? i dont need the console itself but the bracket that relocates
> TIA
