carb kits 600 sedan and glass rubber
Terry-Jo Platt
need 3 carb kits, best ideas? also windshield rubber thanks Terry
Re: carb kits 600 sedan and glass rubber Sources
Check this link on ebay for the carb parts. The bowl gasket works if
you trim off the tabs, the orings fit and the float valve works. Honda
GL1000 carbs look near identical to the N600 carbs. I used this kit on
Joe Ward's carb.
http://cgi.ebay.ca/ws/eBayISAPI.dll?
ViewItem&item=XXX-XXX-XXXX&sspagename=ADME:B:AAQ:CA:1
Rubber parts are supplied by Bill Colford or Mike OConnor.
Joe Ward's carb.
Will this kit work on a 71 z600 carb?
Bill in Missouri
Bill in Missouri
dawn_and_darrian
It looks like the GL1000 and the z600/n600 share more than the carbs.. The oil filter, points, and condenser also appear to be identical.
Miles, do you know if there were any variations between the different years? I am seeing kits for 75 through 79.
Oh, and thanks for the great find :)
I can tell you don't order the air control valve just because it
looks the the accelerator pump, because it's not gonna work.
The GL1000 kit I bought was the earliest possible one. Alternately
the float valve set for a Honda CB550-4 also fits the N/Z600.
riceburner006
--Thanks for this info! The Orings are what is needed most! The bowl
gaskets seem to last forever.I never had much trouble with the
needle and seat either.If your pump clicks real fast then you need
one!I was surprised how cheap these kits are.Found 4 kits for $25,
(no jets included).
In 2cylinderhondas@yahoogroups.com, "Miles Chappell"
(no jets included).
> Joe Ward's carb.
, "Terry-Jo Platt"
