Congrats 700th 2cylinderhondas Member
Post by Miles »
Boy, when I started this back in 2002 I was just hoping to have the
previous subscribers of Novelty News in this group (40 people). As it
grew though it went worldwide. I know there are other forum formats
that are better than Yahoo, but we are all here now and as long as
Yahoo sponsors *groups* we should be able to bond as a family of Honda
owners.
As the group expanded more and more I was hoping to see the day we hit
500 members. Tonight we hit 700 and as far as I can tell the 700th
member was Sprocketford69 who owns 4 600's.
I plan to host a Honda 600 Meet here at my house this year. I haven't
had any for years, but usually had them in October. That might conflict
with the All Japanese Meet in Long Beach Ca though?
I live in Boulder Creek Calif 95006 which is just about 45 minutes from
San Jose Ca. Please email me with best preferred dates for Sept or
October.
isettakurt
Re: Congrats 700th 2cylinderhondas Member
Post by isettakurt »
Boulder Creek?
What happened to Felton? Run out of storage space?
I just spent a week at Camp Lindblad.
Any weekend in September sounds good for a 600 meet.
Dave K.
it
Honda
> owners.
hit
haven't
conflict
from
> October.
easy_stuff_sanchez
Piston rings
Post by easy_stuff_sanchez »
What is a good source for Piston rings ?
How do i know what size do I need ?
What is the ring " Gap " supossed to measure ??
mterrens
Re: Piston rings
Post by mterrens »
This is what I know. Call to confirm.
http://www.honda600coupe.com/Hastings_r ... _600s.html
Good luck,
mterrens
Re: Piston rings
Post by mterrens »
Hey, Hastings has an 800# now:
Toll Free: XXX-XXX-XXXX
Re: Piston rings
Post by Miles »
Hastings doesn't have all 5 sizes available. Last time I checked they
only had STD, .25mm & .50mm oversizes.
The Honda 600 oil ring is an odd height (2.8mm) compared to other
cars. The compression ring is hard chrome plated and is 2.5mm tall,
The 2nd ring is regular cast iron and is also 2.5mm tall. The oil
ring is 2.8mm tall.
There is a couple models of Civic which have 74mm pistons. The oil
ring is 3 pieces and is 3mm tall so you have to widen the slot in
your piston (a machine shop does it) but you get 4 sets that way and
you have spares. It's cheap for the Civic rings. My 1993 Geo Metro
also had 74mm pistons, but I don't recall what the piston rings
looked like, but the wrist pins were the correct diameter and were in
the correct location, so if you didn't mind low performance (concave
tops) it might run?
Don't forget with the Hastings rings to fit them to your bores before
installing them on the pistons. If the gaps are too tight the engine
may seize, too wide and you will burn oil. I believe the correct gap
is .008" to .012".
Your original bore size is 74mm. First oversize would be 74.25mm,
then 74.50mm etc up to 75mm. 75mm is the largest size ofered by
Honda. Sometimes you can still see the numbers on the tops of the
original rings. On the left side of the ring it will have an N or an
R. On the right side it will have nothing or 25 or 50 or 75 or 100.
If it has nothing it is Standard original size.
Re: Piston rings
Hastings will make other sizes, but you have to order and it took almost 6
months to get .75 overs. Another time I ordered .25 overs and received .50
over oil rings. Miles is right but I like Grinding to fit the best, have
your cylinders bored to match the piston (keep cylinders as straight as
possible some shops like to widen them at the lower end). Then when you
receive your rings put them in your new cylinder bore and slide them up and
down the cylinder to find the closest area. Book calls for the top or
compression ring to be .045 to .075 mm and the second ring and oil ring to
be .015 to .045 mm.
I have my bore one point five thousands over the piston size. And while
the pistons and cylinders are at the shop have them weigh the pistons to get
them both the same weight. All this helps when you want to reduce piston
slap and make your engine to be as quite as possible. I have had brand new
pistons weigh in way different, and it all effects performance.
-----Original Message-----
[mailto:2cylinderhondas@yahoogroups.com]On Behalf Of Miles
Sent: Sunday, May 27, 2007 11:50 PM
Subject: [2cylinderhondas] Re: Piston rings
ring is 2.8mm tall.
tops) it might run?
is .008" to .012".
--- In 2cylinderhondas@yahoogroups.com, Steven Michelsen
> From: "Steven Michelsen"
> To: Sent: Sunday, May 27, 2007 2:54 PM
> Subject: Re: [2cylinderhondas] Piston rings
> > Good luck,
> > Steve
> > From: "easy_stuff_sanchez"
> > To: > Sent: Sunday, May 27, 2007 2:11 PM
> > Subject: [2cylinderhondas] Piston rings
> >> How do i know what size I need ?
easy_stuff_sanchez
Re: Piston rings
I may be doing something wrong, my rings measure as follows:
Top= 1.2mm
Mid=1.2mm
Oil=2.2mm
I can easily locate the 74mm bore 1.2mm rings used on a Suzuki engine
SOHC 1.0l(993cc ) or in the 1.3L and in the Honda 1.5L.both
applications come with an oil ring that is 2.8mm.
Can you clarify if the rings needed for the 600 are the 1.2mm for top
and mid and the 2.2mm for oil ??
The hastings catalog Indicates 4 rings 1.5mm and 2 rings 2.5mm
they
> ring is 2.8mm tall.
and
in
(concave
> tops) it might run?
before
engine
gap
> is .008" to .012".
an
, Steven Michelsen
> > To: > Sent: Sunday, May 27, 2007 2:54 PM
> > > Good luck,
> > > Steve
> > > To: > > Sent: Sunday, May 27, 2007 2:11 PM
riceburner006
Re: Piston rings
Post by riceburner006 »
--- In 2cylinderhondas@yahoogroups.com, "easy_stuff_sanchez"
> Top= 1.2mm
> Mid=1.2mm
> Oil=2.2mm
> Hello! I measured a hastings ring set and here are the specs:
Top&2nd compression 1.44 mm or .0575, oil-2.43mm,or .0965.
OEM Honda rings top&2nd 1.46mm or .059, oil 2.47mm or .098.
> This was measured with a digital mike,and a metric digital caliper. riceburner006
> they
> > ring is 2.8mm tall.
> and
> in
> (concave
> > tops) it might run?
> before
> engine
> gap
> > is .008" to .012".
> an
> > Miles
, Steven Michelsen
> > > To: > > Sent: Sunday, May 27, 2007 2:54 PM
> > > > Good luck,
> > > > Steve
> > > > To: > > > Sent: Sunday, May 27, 2007 2:11 PM
