need more help
cotton
need more help
Post by cotton »
I still don't have brakes [too hot to work much and problems] but decided
I didn't need brakes until it was running. I put in a new battery a while
ago. The hot cable coming from battery to starter is hot but I don't have
juice anywhere. Not to ignition or lights,--zip. Is there a master fuse
somewhere?? Any ideas?? I drove it in the shop long ago and it sat
untouched until recently. All ideas appreciated.
Re: need more help
The main fuse is located in a black plastic box between the fender and the right front strut cap.  The battery should have two wires off the positive terminal.  One cable to the starter and the other goes to the fuse box.  The fuse is a 45 amp metal strip located in the box and it is held in place by two screws.  From the 45 amp fuse,  the cables go to the fuse box located under your dashboard.
> I
