Wound up taking gas tank to radiator shop and got it vatted. When
finished he pressured it up. You guessed it, many pin holes in the top. I
had a pk of JB WELD which I put over the worst area and then fiber glassed
the top to the seam. I had the gel which I had never used. It don't go as
far as the thinner glass therefore I didn't get glassed to the seam all
around. I finally got it back on after much cussin and crying. Got
everything hooked back up and on the ground. Started it up and tinkered
with carb for a minute and it was sounding good. Took off and looped the
town a couple times and it was running so sweet I should've know something
was going to go wrong. Got back to house and was
talking to neighbor over the fence when he said I smell gas. Moved the gas
cans to carport and came back and still smelling gas. Checked Connections
at fuel pump & filter --OK Got down on my belly looking up at tank and saw
gas dripping down on the muffler which is full of holes. Was a little
unnerving..
Had all that fun pulling it off again. One small leak at top of seam that
didn't get covered. More JB and got it tight now. Got it back on this
evening but didn't
get in on the ground as I was wore out. 5 hrs easy. test run tomorrow
gas tank
Re: gas tank
Cotton
when I found all the gas leaks in my gas tank I tried the cleaner than the liner stuff you put in after it is clean and dry. I put gravel in the tank to shake it because I could not figure how a chain could get to both sides.. when the rust was gone I put in the cleaner after sealing the hole I could find. well there was a lot of holes and the cleaner went all over the place. after trying a few things I sent it to get renewed and this place http://www.gas-tank.com/ . There are a few places that do this. after about 200 dollars I got my gas tank back and it works fine for me. I know some have had good luck with the other stuff. I do have a can of the liner around some place if anyone needs it.
Tom T
Tom T
> cotton
> Friday, October 10, 2008 8:07
> [2cylinderhondas] gas tank
> talking to neighbor
> cans to carport and
> at fuel pump &
> filter --OK Got down on my belly looking up at tank and saw > gas dripping > down on the muffler which is full of holes. Was a little
> unnerving..
> top of seam that
> back on this
> evening but didn't
Re: gas tank
Tom, I went to our one and only motorcycle shop and he only carried
the older type sealer that was a three step and he only had one can of the three. If he had everything I needed it would have cost over a $100. Fortunately the pin holes were all on top of the tank except for the one on 'the seam. Hope it holds as I sure don't want to take it off/on again.
> TOM THIES
> Saturday, October 11, 2008 1:23
> Re: [2cylinderhondas] gas
> tank
> Cotton
> when I found all the gas leaks in my gas tank I tried the cleaner than > the liner stuff you put in after it is clean and dry. I put gravel in > the tank to shake it because I could not figure how a chain could get to both > sides.. when the rust was gone I put in the cleaner after sealing the > hole I could find. well there was a lot of holes and the cleaner went > all over the place. after trying a few things I sent it to get renewed > and this place > http://www.gas- tank.com/ > . There > are a few places that do this. after about 200 dollars I got my gas tank > back and it works fine for me.
> Checked by AVG -
> http://www.avg.com
> Version: 8.0.173 / Virus Database: 270.8.0/1719 -
> Release Date: 10/10/2008 4:08 PM
Re: gas tank
Hi Cotton;
You really have to think safety here.
Even some of the tank sealers are susceptible to the new alcohol mix we are buying at the pump. I know there are fiberglass gas tanks out there, but I never had much faith in the at home mix if fiberglass. Even JB weld is a good product, but you really have to have the surface super clean for it to work successfully. Or, your asking for more problems. The only product I have had any sustained performance is the stuff from Hirsch Automotive.
www.hirschauto.com or call them at XXX-XXX-XXXX and talk to them about your problem. I had a tank that was rusted and had some pin holes in the bottom and top. The problem is that the tank at that stage is so thin nothing will save it short of replacing the metal. But, I tried some of the Hirsch sealer and it did the trick.
I used a foil tape to give a base for the sealer to fill to and sealed it twice to make sure it was tight. Drove it for a few years before selling it and no problems and no leaks.
Cotton, I have a sign on my garage wall, it reads; "READ THE INSTRUCTIONS - and follow them". Many times I look at that sign, and it knocks me back to reality. Because after working on something for years we like to take short cuts and they normally get us in trouble. So, please be safe.
Re: gas tank
Just got back from a pretty good test drive. Ran sweet up to 60mph and that was all the half decent hi-way I had. Checked for leaks and found none but only had about 3 gal. of gas in it. I wouldn't have trusted fiber glass if holes had been on the bottom. For the JB I used 80 grit sand paper to clean and rough it up, to give it sumpin to bite to. Will keep a close look at it every time I add some gas, a couple gallons at a time.
P.S. Anyone reading this far that has two 5/8 rear wheel cylinder kits,
send me a total delivered price and your mail address and I'll send you a money order for them.
Thanks Bill, Tom, Dale, Dennis and all you guys that have been so much help.
> billmyong@...
> Anzhonda600owners
> Saturday, October 11, 2008 1:13
> RE: [2cylinderhondas] gas
> tank
> Hi
> Cotton;
> here.
> susceptible to the new alcohol mix we are buying at the pump. I > know there are fiberglass gas tanks out there, but I never had much faith in > the at home mix if fiberglass. Even JB weld is a good product, but you > really have to have the surface super clean for it to work > successfully. Or, your asking for more problems. The only > product I have had any sustained performance is the stuff from Hirsch > Automotive.
> www.hirschauto. com
> or call
> them at XXX-XXX-XXXX and talk to them about your problem. I had a tank > that was rusted and had some pin holes in the bottom and top. The > problem is that the tank at that stage is so thin nothing will save it short > of replacing the metal. But, I tried some of the Hirsch sealer and it > did the trick. I used a foil tape to give a base for the sealer to fill > to and sealed it twice to make sure it was tight. Drove it for a few > years before selling it and no problems and no leaks.
> Because after working on something for years we like to take short cuts and > they normally get us in trouble. So, please be > safe.
> > > Checked by AVG -
> > > http://www.avg. com
> > > 270.8.0/1719 - Release Date: 10/10/2008 4:08 PM
> Checked by AVG -
> http://www.avg.com
Kevin Gailey
Re: gas tank
Yes leave the wire in as it dries and pull in and out frequently, or push in and out as drying. The alternative sucks, you have to use a cable and a drill to drill it out and it isn't easy.
bruceb To:
Fri, March 26, 2010 8:08:39 PM Subject:
I'm sealing the gas tank in my 72 sedan. Before i seal it do i need to run a long wire thru the 2 tubes in the tank so they don't get clogged? Any help would be very helpful. Thanks BRUCE
bruceb To:
Re: gas tank
how long are the tubes inside the tank
Re: gas tank
not sure about the vent, but the outlet tube is about 12"/14" long - it runs to the sediment depression at the drain plug.
Whatever you insert will generally stop at 12+/-" because that tube makes a 90 degree turn towards the tank bottom.
Sat, 3/27/10, brucerb@...
Subject: Re: [2cylinderhondas] gas tank
Date: Saturday, March 27, 2010, 10:05 AM
