Can someone tell me the size of the Coupe center rear wheel nut, for removal of the brake drum?
Thanks in advance, Steve
size of Coupe rear wheel nut
Re: size of Coupe rear wheel nut
10mm x 1.5
Sat, 8/15/09, stephen0123
> From: stephen0123
> Subject: [2cylinderhondas] size of Coupe rear wheel nut
> Date: Saturday, August 15, 2009, 5:23 PM
Are you needing to know its size so you can remove it? If so, 22 mm is the size which comes to mind for the coupe and you can use an adjustable Crescent wrench if you do not have the correct size box wrench/socket.
If you want to know is threaded diameter and thread count, I don't know. If no one else chimes in with an answer, I can measure it and let you know.
> Can
> someone tell me the size of the Coupe center rear wheel nut, for removal of > the brake drum?
Kevin Gailey
24mm From:
stephen0123 To:
Saturday, August 15, 2009 5:23:40 PM Subject:
stephen0123 To:
