Oil Seal
franknfike
Oil Seal
Post by franknfike »
Does anybody have a seal for the right side cam holder they would sell me?
Tom
Re: Oil Seal
Post by Miles »
Standard size metric seal, you can order from any bearing store.
> Tom
Re: Oil Seal
Hi Tom,
    Let us know how successful you are at finding the seal and what additional details are needed to order the seal.  The size of the seal is listed as 20 x 30 x 5.    I would suggest you take in a seal which is not damaged (one of the other seals from the engine or clutch area) so they can see what you are trying to buy.  If you just give them the size (20 x 30 x 5),  they are going to start asking a bunch of questions such as;
1) radial, axial, or symmetrical ?   ( I believe it is radial )
2)  single or double lip?  (single)
3)  material?    (polymer and I think the material is nitrile)
4) operating speed  (about 750 ft/min)
5) temperature range (400 degrees F)
Hopefully you find a salesperson with lots of patience.  If you end up having to buy a bunch of them to meet the minimum order requirement,  you should be able to sell them to the group.
> In
> "franknfike" wrote:
> > Does anybody
> > Tom
Charles m
Re: Oil Seal
Post by Charles m »
Guys,
You can order this on line. Just do a search for metric seals and enter the number.
Chuck M.
Date: Mon, 17 Aug 2009 13:37:32 -0400
Subject: Re: [2cylinderhondas] Re: Oil Seal
Hi Tom,
> > Thanks,
> > Tom
With Windows Live, you can organize, edit, and share your photos.
Click here.
