fuse?
deantds
fuse?
Post by deantds »
hi i have been working on my wiring harnace and have a question there is a wire that goes to the key switch that each end of the wire is female. on my car there is a home made jumper that connects them together. was this jumper once a fuseable link or in line fuse? my wire diagram is not clear on the switch as the wire code does not match the switch wire colors. thanks for any help. dean
Healthcare Administration
Earn your AA or BA in Healthcare Administration, 100% online.
http://thirdpartyoffers.netzero.net/TGL ... NiiQAAAAA=
Kevin Keough
Re: fuse?
Post by Kevin Keough »
if it was me i would put a 20 amp fuse in the middle of it just for shit and jiggles. heres some pics of some new projects Kevin
Wed, 11/18/09,
deantds
> From: deantds
> Subject: [2cylinderhondas] fuse?
> Date: Wednesday, November 18, 2009, 6:37 PM
> http://thirdpartyoffers.netzero.net/TGL ... NiiQAAAAA= > ------------------------------------
Kevin Gailey
Re: fuse? [3 Attachments]
Post by Kevin Gailey »
Wow Kevin, that is alot of 600's.  You are in NorCal aren't you?  I am in Sacramento and would love to see the cars and pick your brain.
Kevin Gailey From:
Kevin Keough To:
Wed, November 18, 2009 11:00:30 AM Subject:
Re: [2cylinderhondas] fuse? [3 Attachments]
Wed, 11/18/09,
deantds
> From: deantds
> hi i have been working on my wiring harnace and have a question there is a wire that goes to the key switch that each end of the wire is female. on my car there is a home made jumper that connects them together. was this jumper once a fuseable link or in line fuse? my wire diagram is not clear on the switch as the wire code does not match the switch wire colors. thanks for any help.. dean > ____________ _________ _________ _________ _________ _________ ___ > Healthcare Administration > Earn your  AA or BA in Healthcare Administration, 100% online.
> http://thirdpartyof fers.netzero. net/TGL2241/ c?cp=QqDo4yquuFh lzmGenK3xVgAAJ1F Jewj2ooRpTcZqlpE Om2q_AAQAAAAFAAA AAGPnvj8AAAMlAAA AAAAAAAAAAAAAAAN > iiQAAAAA= > ------------ --------- --------- ------
Kevin Keough
Re: fuse?
sorry Kevin I'm in Washington state and that's only a few of them currently have 8 sedans and 4 coupes some are runners and stoppers some are parts please email me off page with any questions or parts requests thanks Kevin
Wed, 11/18/09, Kevin
Gailey
> From: Kevin Gailey
> Subject: Re: [2cylinderhondas] fuse?
> Date: Wednesday, November 18, 2009, 8:08 PM
> Kevin Gailey
> Kevin Keough
> if it was me i would put a 20 amp fuse in the middle of it just for shit and jiggles. heres some pics of some new projects Kevin > --- On > Wed, 11/18/09, > deantds
> > From: deantds
> > hi i have been working on my wiring harnace and have a question there is a wire that goes to the key switch that each end of the wire is female. on my car there is a home made jumper that connects them together. was this jumper once a fuseable link or in line fuse? my wire diagram is not clear on the switch as the wire code does not match the switch wire colors. thanks for any help.. dean > > ____________ _________ _________ _________ _________ _________ ___ > > Healthcare Administration > > Earn your  AA or BA in Healthcare Administration, 100% online.
> > http://thirdpartyof fers.netzero. net/TGL2241/ c?cp=QqDo4yquuFh lzmGenK3xVgAAJ1F Jewj2ooRpTcZqlpE Om2q_AAQAAAAFAAA AAGPnvj8AAAMlAAA AAAAAAAAAAAAAAAN iiQAAAAA= > > ------------ > > --------- --------- ------
Re: fuse?
Post by feltonminicycle »
There's no fusible link there. The only fusible link is under the hood, a 45 amp in the main fuse block.
The ign switch colors never match up. I am in Santa Cruz working almost everyday, just call me I can come by.
dean m
Re: fuse?
Post by dean m »
hey miles this is not the dean in santa cruz , just so you know im the dean in santa cruz  my wiring is fine  thanks
Thu, 11/19/09, feltonminicycle
> From: feltonminicycle
> Subject: [2cylinderhondas] Re: fuse?
> Date: Thursday, November 19, 2009, 8:03 AM
deantds
Re: fuse?
Post by deantds »
thanks miles but this is deantds in vacaville...a little farther towards sacramento. thanks for your offer though.
Medical Insurance Quotes
Compare medical insurance companies and save money now.
http://thirdpartyoffers.netzero.net/TGL ... iWIAAAAAA=
Re: fuse?
Hi Dean,
   If you have an original Honda ignition switch,  here are some notes I made years ago to show how it matches up to the wiring harness;
switch wire color ...............wiring harness color ............  ignition switch position
red    white  .............................battery (+12 volts)
red/black stripe    black/white stripe ............ starter solenoid
black  black/yellow stripe .......... ignition
yellow    white/red stripe ................. accessories
grey    no connection,  not used on AZ600
Verify the heavy gauge red wire does have +12 volts on it since you don't want to hook this wire at the wrong switch position.
> hi i
> have been working on my wiring harnace and have a question there is a wire > that goes to the key switch that each end of the wire is female. on my car > there is a home made jumper that connects them together. was this jumper once > a fuseable link or in line fuse? my wire diagram is not clear on the switch as > the wire code does not match the switch wire colors. thanks for any > help
Deans
That makes 2 Deans in Santa Cruz, the other Dean has a yellow coupe that he cherried out even though it was a mint 10,000 mile car with no flaws. He repainted it and chromed everything under the hood.
Kevin Keough
Re: Deans
hay miles sent your shocks yesterday should be there let me know what you think if you would send me your phone# to my email i would like to chat thanks Kevin
Fri, 11/20/09,
> Subject: [2cylinderhondas] Re:Deans
> Date: Friday, November 20, 2009, 3:50 PM
> , "deantds" wrote:
> > thanks miles but this is deantds in vacaville... a little farther towards sacramento. thanks for your offer though.
> > ____________ _________ _________ _________ _________ _________ _ > > Medical Insurance Quotes > > Compare medical insurance companies and save money now.
> http://thirdpartyof fers.netzero. net/TGL2241/ c?cp=et3lqNU7Fk7 kdUFkBkTz5QAAJ1F Jewj2ooRpTcZqlpE Om2q_AAQAAAAFAAA AAPgmiD4AAAMlAAA AAAAAAAAAAAAAAAi WIAAAAAA=
