Z flywheel questions
glen c
Post by glen c »
I picked up a Z that the owner has the starter out and said the solenoid was bad...looking at it tho, it looks like the ring gear is chewed up.
Questions are, can i remove the flywheel and turn the ring gear over like we used to do on older flywheels or is it a one piece set up and have to replace the flywheel? Can the flywheel be removed with engine in the car?
Thanks, Glen
Re: Z flywheel questions
Hi Glen,
   If you are able to remove the ring gear (sometimes they get rusted in place),  you can flip it over.  The work can be done in the car.  Easy to do if you have a rotor removal tool.
> I
> picked up a Z that the owner has the starter out and said the solenoid was > bad...looking at it tho, it looks like the ring gear is chewed > up.
> Questions are, can i remove the flywheel and turn the ring gear > over like we used to do on older flywheels or is it a one piece set up and > have to replace the flywheel? Can the flywheel be removed with engine in the > car?
> Thanks, Glen
glen c
Post by glen c »
Thanks Dale..
Does anyone happen to have a picture of the tool needed? I'm pretty handy at making such things, a pic would be nice tho...
Glen
, goinhm@... wrote:
> Hi Glen,
> good luck,
> Thanks, Glen
infinkc
Post by infinkc »
i will snap a pic of the one i have, Miles sells them.
, "glen c" wrote:
> Thanks Dale..
> Glen
, goinhm@ wrote:
> > Hi Glen,
> > good luck,
> > Dale
> > Thanks, Glen
Love
Post by Love »
The puller is in the tools album on facebook:
http://www.facebook.com/posted.php?id=1 ... 5970153346
If you search archives, you'll discover what oil plug fits (hint: anz600owners group).
Bruce D.
infinkc To:
Mon, May 23, 2011 11:04:25 AM Subject:
[2cylinderhondas] Re: Z flywheel questions
, "glen c" wrote:
> Thanks Dale..
> Glen
, goinhm@ wrote:
> > Hi Glen,
> > If you are able to remove the ring gear (sometimes they get rusted in > > place), you can flip it over. The work can be done in the car. Easy to do > > if you have a rotor removal tool.
> > good luck,
> > Dale
> > I picked up a Z that the owner has the starter out and said the solenoid > > was bad...looking at it tho, it looks like the ring gear is chewed up.
> > Questions are, can i remove the flywheel and turn the ring gear over like > > we used to do on older flywheels or is it a one piece set up and have to > > replace the flywheel? Can the flywheel be removed with engine in the car?
> > Thanks, Glen
