antenna N600
antenna N600
Can someone tell me the correct routing for the antenna wire for a 72 sedan??
Re: antenna N600
Did you get your answer? When I have removed the antenna from a sedan, the cabling has gone down the body work behind the left side door to the bodywork channel which runs below the left side door. Once it gets in front of the door, it rises up and goes into the dash.
> Can someone tell me the correct routing for the antenna wire for a 72 > sedan??
Re: antenna N600
I emailed the info, but forgot to mention there is a lip formed in the left plastic for the cable to run in
> good luck,
> sedan??
John Mills
Re: antenna N600
Yes, Miles sent me the correct routing. I couldn't figure it out as the hole where the cable exits under the door had been covered with a thin round piece of tape and I had painted over it so did not seem right. Thank you all. I sure could use the piece of plastic that covers the cable under the door. The long black piece. Mine is pretty much destroyed. Any out there??
Re: antenna N600
Those plastic pieces are always trashed on a sedan. Always perfect on a coupe. Weird.
> From: goinhm
> To: 2cylinderhondas Sent: Mon, May 23, 2011 10:55 pm
> Subject: Re: [2cylinderhondas] antenna N600
> good luck,
> good luck,
