Need brake cylinders and master cylinder
Paula Allen
Post by Paula Allen »
Rebuilding brakes on 1971 600 and need rebuilt wheel and master cylinders...thanks to any suggestions or responses...
Jennifer F. Kidder
Re: Need brake cylinders and master cylinder
Post by Jennifer F. Kidder »
you know about
http://www.honda600carparts.com/brakes.html right?  rebuilt master cylinder =$217.55!!!!!!!!!   $65.00 core --btw is that price high, low, or about medium? 'cause I'm working on my breaks too.
so, if you were looking for another idea than that website,  what might that be?...?
-skip
> Paula Allen
> Saturday, August 10, 2013 8:34 AM
> [2cylinderhondas] Need brake cylinders and master cylinder
Jennifer F. Kidder
mechanical symptom advice ???
hey folks, I don't know if you guys do this, I'm hoping your collective expertise can tell me what I'm missing:
my '71 N600  Won't Idle!.  I feel like I've been trying to keep it from stalling for 10 years!  but that parinoia might be because that's  how long it has sporatically stalled While I'm  Barreling Along in the Fast Lane!  at the advice of various mechanics, I &/or they have:  swapped out the fuel pump, batttery,  spark plugs / leads,  cleaned carborater & air filter, ...I don't know what else!  & these things haven't worn out again; barely driven over past several years because it's so depressing : sometimes the problem is solved for 3blocks!, 10 miles, 1 month,...
last thing  done was new fuel filter. (~2weeks ago) & I paid a mechacic alot to get to the bottom of this problem; that's all he did, & now it's theatening to stall again!  {I really donot wish to disparage this last guy. everyone who  has worked on or helpedme work on this issue, says "yeah, that's not a problem anymore" or worse"it never was"} anyway, I had thought the fuel filter made sense. :( Now What???
--skip
Dean
Re: mechanical symptom advice ???
Post by Dean »
I would take the carb apart and clean out the inner parts if you havnt done so I'm betting the problem is with in the carb ..... You can use a carb kit from an early goldwing motorcycle 74-76 I believe you can find these on eBay Sent from my iPhone
On Aug 10, 2013, at 11:30 AM, "Jennifer F. Kidder" wrote:
hey folks,
--skip
Jennifer F. Kidder
diditRe: [2cylinderhondas] mechanical symptom advice ???
yep, did that already.  what else y'got?
& thanks for the good idea; it helped alot when I did it ~3yrs ago :) --skip
> Dean
> "2cylinderhondas@yahoogroups.com"
> Saturday, August 10, 2013 11:36 AM
> I would take the carb apart and clean out the inner parts if you havnt done so I'm betting the problem is with in the carb ..... You can use a carb kit from an early goldwing motorcycle 74-76 I believe you can find these on eBay > Sent from my iPhone > On Aug 10, 2013, at 11:30 AM, "Jennifer F. Kidder" skippieiam@...
> > hey folks,
> > ago) & I paid a mechacic alot to get to the bottom of this problem; that's all he did, & now it's theatening to stall again!  {I really donot wish to disparage this last guy. everyone who  has worked on or helpedme work on this issue, says "yeah, that's not a problem anymore" or worse"it never was"} > > anyway, I had thought the fuel filter made sense. :( > > Now What???
> > --skip
Charles Gould
Post by Charles Gould »
Are you sure it is only during idle? because you said that it stalled while you were barreling along in the fast lane. If it were a fuel starvation issue, it would occur at higher RPMs as well. If it were a clogged idle jet, it would just happen at idle.
Sounds like an intermittent electrical problem to me. Possibly a bad ground from engine or more likely, a loose wore or short at the points or condenser. Check for broken wire insulation or a missing or bad insulator washer.
It could also very likely be a bad ignition coil or condenser, which would be worse as the coil heats up.
Chas Sent from my iPhone
On Aug 10, 2013, at 2:30 PM, "Jennifer F. Kidder" wrote:
hey folks,
--skip
Re: diditRe: [2cylinderhondas] mechanical symptom advice ???
Post by Eric Geiger »
my car was recently being a little bitchy as well,  fully rebuilt carb by Miles, less than 200 miles ago, new fuel filter, all new NOS points, condenser, new timing chain, valves adjusted,  spark plugs, vacuum advance was working fine, literally everything had been checked over and over/gone through and all was within spec and it was timed multiple times using a static light.   still it would sputter/bog down on me every now and then when taking off at a stop light or if i shifted into too high of a gear for the rpms.  even would die sometimes at a stop light for no reason.
i advanced the timing ever so slightly and it runs better than ever.
maybe that will do the trick for you as well.
Eric J. Geiger
PRG Nocturne
XXX-XXX-XXXX  phone
XXX-XXX-XXXX  fax
XXX-XXX-XXXX  mobile
egeiger@...
www.prgnocturne.com
> --skip
> > Dean > lt1ski@...
> > " > 2cylinderhondas@yahoogroups.com
> > Sent from my iPhone
> > On Aug 10, 2013, at 11:30 AM, "Jennifer F. Kidder" > skippieiam@...
> > > wrote:
> > > hey folks,
> > > my '71 N600  Won't Idle!.  I feel like I've been trying to keep it from stalling for 10 years!  but that parinoia might be because that's  how long it has sporatically stalled While I'm  Barreling Along in the Fast Lane!  at the advice of various mechanics, > > > I &/or they have:  swapped out the fuel pump, batttery,  spark plugs / leads,  cleaned carborater & air filter, ...I don't know what else!  & these things haven't worn out again; barely driven over past several years because it's so depressing : sometimes > > > the problem is solved for 3blocks!, 10 miles, 1 month,...
> > > last thing  done was new fuel filter. (~2weeks ago) & I paid a mechacic alot to get to the bottom of this problem; that's all he did, & now it's theatening to stall again!  {I really donot wish to disparage this last guy. everyone who  has worked on or helpedme > > > work on this issue, says "yeah, that's not a problem anymore" or worse"it never was"}
> > > Now What???
> > > --skip
Coker (King 145R-10 Tires)
Pricing note:
Summit Racing Equipment http://www.summitracing.com/   or call for order at 1.XXX-XXX-XXXX to order these tires at $64.00 each to beat the Coker price and right now they have a special free shipping for orders over $99.00.  So your order will be $256.00 to your door unless there is tax.  That is about the best deal going.
dm600z
Post by dm600z »
Hi  Skip,
    If your car works at 55 mph (which requires lots of air and lots of fuel) but doesn't work well at idle  (which requires only a little fuel and a little air) then the problem is NOT going to be with the
a) fuel pump
b) battery
c) air filter
d) spark plugs
e) fuel filter
Your problem is most likely in
a) the idle circuit of the carb
b) vacuum leak  (check the boot where the carb attaches to the engine
c)  problems with the pistons rings / engine compression
d)  ignition/ timing
The problem is usually the carb or vacuum leak.
PS   you seem to have spent some bucks not getting your problems solved.  Your money would have been better spent going over to the local community college and taking a course on how a car works.
> hey folks,
> my '71
> N600  Won't Idle!.  I feel like I've been trying to keep it from > stalling for 10 years!  but that parinoia might be because that's > how long it has sporatically stalled While I'm  Barreling Along in the > Fast Lane!  at the advice of various mechanics, I &/or they > have:  swapped out the fuel pump, batttery,  spark plugs / > leads,  cleaned carborater & air filter, ...I don't know what > else!  & these things haven't worn out again; barely driven over past > several years because it's so depressing : sometimes the problem is solved for > 3blocks!, 10 miles, 1 month,...
> (~2weeks ago) & I paid a mechacic alot to get to the bottom of this > problem; that's all he did, & now it's theatening to stall again!  {I > really donot wish to disparage this last guy. everyone who  has worked on > or helpedme work on this issue, says "yeah, that's not a problem anymore" or > worse"it never was"} > anyway, I had thought the fuel filter made sense.
> Now What???
> --skip
Jennifer F. Kidder
WOW! You guys rock! just got these & will begin ruminating over --skip
> Charles Gould
> "2cylinderhondas@yahoogroups.com" > Cc:
> Saturday, August 10, 2013 11:54 AM
> Chas
> Sent from my iPhone
> On Aug 10, 2013, at 2:30 PM, "Jennifer F. Kidder" skippieiam@...
> > hey folks,
> > --skip
