Seat belt tensioners
bobs600honda
Post by bobs600honda »
Any trick to getting the front seat belts to retract full? Oil / graphite / grease?
Thanks for any suggestions,
Bob
Re: Seat belt tensioners
I like spray silicone.  WD will work,but it collects dust.
Pull the belt assembly and pull it all the way out on the real, then use the spray silicone liberally and cycle the belt back in several times.  If there is any wear or damage that will have to be straightened.  Otherwise it should work fine.
David Romero
Post by David Romero »
As Bill mentioned, it WILL work gain. I think I used a lot of lithium grease and just worked the belt in and out as much as I could. After 5 minutes the belt will work perfectly.
On Wed, Aug 28, 2013 at 5:56 AM, bobs600honda
> Bob
Robert James
Post by Robert James »
Thanks, great suggestions!
On Thu, Aug 29, 2013 at 11:49 AM, David Romero
> rjamesblues@...
> > Bob
