when I rev the engine...between 1500 and 2000 rpm, the whole car shakes some..you don't feel it much while
driving,but when you rev a little to take off from a light...you feel it...maybe a worn mount?
engine vibration...motor mounts??
Bryan O_Shaughnessy
Re: engine vibration...motor mounts??
Certainly could be motor mounts, but if it only occurs, between two points on the RPM scale, it could be a "harmonic" vibration. See if your exhaust system is hanging loose or is somewhere touching the bottom of the car. ---Bryan O
> when I rev the engine...between 1500 and 2000 rpm, the whole car shakes some..you don't feel it much while > driving,but when you rev a little to take off from a light...you feel it...maybe a worn mount?
