Timing troubles?
a-younger
Timing troubles?
Post by a-younger »
Where should we look first?
My Father's AN600 used to backfire when going down a hill without pressing the gas; and didn't have any trouble accelerating. Now, no backfire, Dad says it lugs badly. And the spark plugs are gunky indicating a rich fuel mixture.
Anyone familiar with these symptoms, or know the area to go to?
Thnx in advance,
ave
d~~~ moran
Re: Timing troubles?
Post by d~~~ moran »
Timing moved?
a-younger@... [2cylinderhondas] ;
[2cylinderhondas] Timing troubles?
Thu, Nov 20, 2014 7:04:19 PM
Thnx in advance, ave
a-younger
Post by a-younger »
It's what my Dad thinks. He'll be checking the chain once the light is right.
d~~~ moran
Timing moved?
bottom cop
Post by bottom cop »
Timing, vacuum advance or carberator diaphram. MAYBE more than one.
On Thu, 11/20/14,
a-younger@...
Subject: [2cylinderhondas] Timing troubles?
Date: Thursday, November 20, 2014, 2:04 PM
mixture.
to?
Thnx in advance,
ave
Miles Chappell
Post by Miles Chappell »
If you have a hole in the exhaust up near the down pipe where the exhaust is still hot decellerating down a hill will cause popping  or back firing.
Clean the carb, check the points and condenser, sooty plugs could mean a number of things, not excluding timing or a rich carb.
