Lower the height
tonipereztf
Lower the height
I wanted to lose some height z. How could I? Could cut the front springs?
Re: Lower the height
You need to cut the front springs, and for the rear, you need square tube, and custom u bolts, look at my photos, I have some rear pics of it, there is a guy on ebay that makes the custom u bolts for you.
Sent from my T-Mobile 4G LTE Device
Date:11/28/2014 7:36 AM (GMT-08:00)
Subject: [2cylinderhondas] Lower the height
tonipereztf
Where could see those photos you say?
It is on the yahoo groups for the n600, it's Arts jdm n600 conversion I believe, in the photo section
Date:11/28/2014 10:14 AM (GMT-08:00)
Subject: RE: [2cylinderhondas] Lower the height
pommecoing
Hello. Who is this guy on eBay who makes custom U bolts please ? Thank you.
I have a lowered coupe (lowering by Miles C.) that use sedan struts that are 1" lower, and spacer blocks for the rear axle. I don't think the u-bolts are custom. Anyhow, the handling is much better than stock.
Bruce D.
Grass Valley CA
"artremai artremai@... [2cylinderhondas]"
Friday, November 28, 2014 9:16 AM
Sent from my T-Mobile 4G LTE Device -------- Original message -------- From: "tonipereztf@... [2cylinderhondas]" 2cylinderhondas@yahoogroups.com> Date:11/28/2014 7:36 AM (GMT-08:00) To: 2cylinderhondas@yahoogroups.com Subject: [2cylinderhondas] Lower the height
Bruce D.
Grass Valley CA
pommecoing
A better handling is what I'm looking for. I'll build custom spacer blocks. But if I do so, the stock U-bolts will be too short. What heighth would you advise for a correct lowering ?
For the front : don't know if I'll be able to say what I mean in english... You suggest to cut the front springs. But the last coils of the stock front springs are shaped to fit in the bottom and top "spring retainers" of the struts. If you cut the springs without shaping their ends, they won't fit in the "retainers".
Do not hesitate to change my vocabulary if you don't understd my poor english.
Thank you.
Thank you.
pommecoing
"Spring seats" sounds better than "spring retainers".... Thank you.....
Most trailer repair shops can build new u bolts. It u take your old ones in to the shop and just ask them to make new ones with the same curve but longer.
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
PRG-Nocturne
XXX-XXX-XXXX
Egeiger@...
On Nov 29, 2014, at 12:46 AM,
pomier.cohen@...
Thank you.
tonipereztf
Me vuelvo loco. El traductor de google traduce tonterias. Yo no entiendo nada.
Me pregunto si existen unos muelles de otros veh�culos que tenga medidas similares pero fuesen mas cortos.
I'll go crazy. Google translator translates nonsense. I do not understand anything.
I wonder if there are no shorter springs another vehicle that can adapt.
