looking for Z600 parts? I've got the car
johndanielmorse
Post by johndanielmorse »
I have a 1972 Z600 that I intended on restoring but I have run out of funds to fix the problems with the motor and the suspension. The rest of the car is in fairly good shape and I have worked on some of the other pieces of the car. I am looking for someone interested in the parts. The car is in Northern California.
John
dusty path
Re: looking for Z600 parts? I've got the car
Post by dusty path »
hello John what u want just for the engine as I can always use parts  and what year  is it ??  or what  u want for the hole car ??  and were in Cali are u ??
On Wednesday, July 5, 2017 8:08 AM, "johndanielmorse@... [2cylinderhondas]" wrote:
John
Chuck Dean
Post by Chuck Dean »
I would be interested in the driver side interior door card if it is in perfect condition.
Our 1972 Honda 600 Coupe
On Jul 5, 2017, at 8:08 AM,
johndanielmorse@...
John
johndanielmorse
I am in northern Calif. (Walnut Creek) The engine is in pieces at a shop, has been for quite a while. A "friend" of mine said that he could fix it, the engine had seized up and has pits in one of the cylinders. If you wanted the engine, it would come to you in a box. The car should be used for parts. I am trying to be as straight forward as I can. The asshole who sold it to me really rat reamed me. I don't want to do it to the next guy. But with that being said, there are several pieces that are in pretty good shape.
John
johndanielmorse
Nothing on this car is perfect condition. Sorry.
Post by Steve »
It's easy to get the cylinders rebored to a larger size and Hastings has various size rings. Even if you used all Civic rings and had the oil ring lands widened to accept the 3mm oil rings (N600 is 2.8mm) you could do that. Or find another set of jugs to fit your pistons though most STD jugs are beyond spec. The expensive part about the engines is when the crankshaft assy is bad but finding a used crank is also possible.
johndanielmorse
Thanks Miles. Unfortunately, the chain tensor is also shot. Struts are worn out. It has become a lot bigger job than I can afford. But thanks for the info. I will most likely send it on with the next person who tackles the car.
John
Andy Hale
Post by Andy Hale »
Hi John, if your parting the car is the bodywork good enough to provide some repair panels? Looking for rear wheel arches, rear valance & inner front wing parts - for use in the UK - already sourced some sills from the US! Cheers Andy
alanstanyon
Post by alanstanyon »
Maybe we should import a whole car Andy!
johndanielmorse
Hey Miles, I made some calls about boring the cylinders, I was told that they could be honed and the same pistons could go back in, but that if I bored them to "twenty thousandths" that the same pistons could not go back in because they would be sloppy. When you gave me this advice did you mean I needed to get new pistons as well as the rings? (are those the jugs you were referring to?) The way you were talking about grinding the piston to get the 3mm Civic rings on, it didn't seem like it, but I am not all that knowledgeable in that area. You made it sound fairly simple but I think I need more of an explanation. Thanks,
John
