Does anyone know if you have drop the engine and k member to change?
Thx, Kevin Gailey
72 Z
Sent from my iPhone
Rear engine mount
Alan Stanyon
Re: Rear engine mount
It's fiddly but can be done, take the weight of the car body on jacks or stand's,
loosening the rear sub-frame bolts
and packing the frame away from the body whilst supporting the engine give's a little more "wiggle" room.
2cylinderhondas@yahoogroups.com on behalf of Kevin Gailey krgailey@... [2cylinderhondas]
17 August 2017 03:25
[2cylinderhondas] Rear engine mount
Thx, Kevin Gailey
72 Z
Sent from my iPhone
Thx, Kevin Gailey
72 Z
Sent from my iPhone
Kevin Gailey
Thx a lot Alan!
Sent from my iPhone
Sent from my iPhone
On Aug 16, 2017, at 8:46 PM, Alan Stanyon
alanstanyon@...
take
the
loosening
krgailey@...
[2cylinderhondas] <
Thx, Kevin Gailey
72 Z
Sent from my iPhone
One of the things which will determine how much trouble you will encounter is the direction of the 4 bolts holding the mount to the engine casing. If the nuts are at the bottom, you will need enough clearance to remove the bolts from the top. If the nuts are at the top, you are going to have a tough time. Portions of the exhaust are going to need to be disconnected. You will need to loosen the front 2 subframe bolts and remove the rear 2 botls. You will need to monitor the speedo cable, starter wiring, fuel line to carb, and distributor wiring.
In a message dated 8/16/2017 8:46:33 P.M. Pacific Daylight Time, 2cylinderhondas@yahoogroups.com writes:
> take
> the
> loosening
> and packing
> the frame away from the body whilst supporting the engine > give's a little more "wiggle" room.
> on behalf of Kevin Gailey > krgailey@... [2cylinderhondas] > > Sent:
> 17 August 2017
> 03:25
> Does anyone know if you have drop the engine and k member to > change?
> Thx, Kevin Gailey
> 72 Z
> Sent from my
> iPhone
