I think every owner will tell you that if you unbolt the ignition switch from the key way you can use a screw driver to turn it to start your car. I think there is something else in the mix. Try touching the hot lead to the battery bolt on your starter if it turns then switch the ignition switch on and see if it will start. If not, then you need to look else where.
> jason
> hambelton
> 2cylinderhondas
> Sunday, September 01, 2002 1:09
> [2cylinderhondas] Starting
> problems!
> As a newer owner to a set of Honda 600, I think that I may have > caused my own problems. A few month's ago I bought a 72 600N, it had > been sitting out in a dirt lot for a few years. The guy I got it from > had long ago lost the keys, so I drilled out the two retaining bolts to unlock > the steering. Then I lucked out and got a 72 600Z at a storage auction > (only $5.00 for the car!) same thing no keys, get the drill out to get the car > home.
> Now is where I have the problem, the first car got it cleaned up put > together use a screwdriver to turn the switch, no spark. Rechecked > everything same problem. When I got the second car same thing > again. So my question is, if the ignition assembly is not bolted on and > turned with the key will this cause no spark problem? I think it is a > far fetched idea, but I got the same results with both cars.
> Thanks for any help or ideas,
> Jason
> Do You Yahoo!?
> Yahoo!
> Finance
> - Get real-time stock quotes
> To
> to:
> Your
> Yahoo! Terms of Service
