Re: seat covers!
riceburner006
Re: seat covers!
Post by riceburner006 »
That's great! I'm sure many of us need them NOW! Please give us more
Info. on Availability,application,installation,and pricing.
Re: seat covers!
As I said earlier, installation is the reverse of removing your old
seat covers. A simple "Hog Ring" crimpier, needle nose pliers along with
spray glue ALA 3M and your in. Removing your old covers is more than just
pulling them off. The covers are glued to the Foam Rubber cushion and care
must be take not to rip them up. If your intending to have the foam rubber
replaced then rip away. Gluing the new covers on is simple if you remember
one trick. Use spray on contact cement, let it dry to the touch and then
slip a pre cut piece of cardboard between the cover and the foam rubber
until you have the new cover in the right position. Then pull the cardboard
out and press the cover into the seat.
Availability is within a few days of receipt of your check or money
order. Each is made when ordered and any color is ok as long as it's
Black.
Attached is another look at the rear seat installed.
