exhaust manifold and heat exchanger gaskets?
mterrens
Post by mterrens »
I am contemplating pulling the exhaust manifolds, heat exchanger and heat shields for cleanup and painting.  DOes anyone know what material the gaskets for these are made of?  Can I fabricate them myself, or are they available from a retail source or a listmember?  Also, are there any particular issues to be aware of when pulling these parts?  I intend to leave the engine in place.
Also, I would like to use POR-15, the rustproofing coating, on these items.  Does anyone know if POR-15 is high-temp compatable?
Re: exhaust manifold and heat exchanger gaskets?
Hi Steve;
    The POR15 is worthless on exhaust parts and they will tell you as much.  I have used is successfully to do under coat and wheel wells.
But not where it will receive direct sunlight.  It works very well on the subframe.  Go to www.hirschauto.com for some really good high temp paint.  As to the gasket manifold, the Copper O rings are very close to the Honda CBR 650 copper gaskets.  The rest I would leave together.
    If your going to freshen up your engine and exhaust system, I would pull the engine.
    I use Hirsch Auto High temp aluminum.
The stuff gets brighter the more it heats up.
See attached picture.   I had this engine in a car for about a year.  The exhaust header and heat riser were all painted with Hirsch high temp systems.
riceburner006
Post by riceburner006 »
--- In anzhonda600owners@yahoogroups.com, Steven Michelsen
> Steve
Go to masterseriescoatings.com,use permanent rust primer for heat-
exchanger,and ask about Hi-temp jet coating for manifolds. Works
great! Silver rust paint good up to 350 and grey jet coating to
about 1800 degrees.
D
Post by D »
Steven Michelsen
Hi Steven: I disassembled my manifolds, then sandblasted and immediately sprayed them with Pep Boys aluminum high temp enamel. The longer I drive it the shinier it gets. I made gaskets out of an asbestos base gasket material, which all failed in about a month. Then I made gaskets out of sheet copper with a thin film of Permatex "Ultra Copper" silicone gasket maker on both sides, which ended all leaks. Good luck!
riceburner006 wrote:
> --- In anzhonda600owners@yahoogroups.com, Steven Michelsen > wrote:
> > I am contemplating pulling the exhaust manifolds, heat exchanger > and heat shields for cleanup and painting.  DOes anyone know what > material the gaskets for these are made of?  Can I fabricate them > myself, or are they available from a retail source or a listmember?
> Also, are there any particular issues to be aware of when pulling > these parts?  I intend to leave the engine in place.
> > Also, I would like to use POR-15, the rustproofing coating, on > these items.  Does anyone know if POR-15 is high-temp compatable?
> > Thanks,
> > Steve
> Go to masterseriescoatings.com,use permanent rust primer for heat- > exchanger,and ask about Hi-temp jet coating for manifolds. Works > great! Silver rust paint good up to 350 > and grey jet coating to > about 1800 degrees.
> Yahoo! Terms of Service
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
PatrickJHamilton
Post by PatrickJHamilton »
Hi!
Are the copper O-Rings from the Z-Honda the same as for the N-HONDA?
Do you have a part number for the copper O-Rings from CBR 650?
Thanks!
Jochen
> william
> colford
> Thursday, June 19, 2003 8:11
> Re: [anzhonda600owners] exhaust
> Hi Steve;
> and they will tell you as much.  I have used is successfully to do under > coat and wheel wells.
> www.hirschauto.com
> high temp paint.  As to the gasket manifold, the Copper O rings are very > close to the Honda CBR 650 copper gaskets.  The rest I would leave > together.
> aluminum.  The stuff gets brighter the more it heats up.
> for about a year.  The exhaust header and heat riser were all painted > with Hirsch high temp systems.
> > Steven
> > Michelsen
> > Honda group
> > Wednesday, June 18, 2003 8:38
> > PM
> > exchanger and heat shields for cleanup and painting.  DOes anyone know > > what material the gaskets for these are made of?  Can I fabricate them > > myself, or are they available from a retail source or a listmember?
> > Also, are there any particular issues to be aware of when pulling these > > parts?  I intend to leave the engine in place.
> > coating, on these items.  Does anyone know if POR-15 is high-temp > > compatable?
> > Thanks,
> > Steve
> > to:
> > Your
> To
> to:
> Your
