Is it possible to straiten a bent valve, or where can I get a new
one for a honda n360.
Bent Valve
Re: Bent Valve
Matt, It's not a good idea to try and straiten it, you will never get it
seated again, and even if you did, you most likely could pop the top of
the valve off and wreck your top end, its not a good idea, if you cant
find a new one I'm sure one of the members will have a good used one you
can get and regrind.
You will here from someone soon I'm sure.
Do you know if the valves are the same in the 600s if they are I have
two part engines coming around the middle of April, if you don't get an
answer from someone else.
Dan
Dan
