dumb question #3 - solenoid identification
mterrens
Post by mterrens »
While pondering my unwired engine and my Coupe wiring diagram, I see that
what I believe is the solenoid (mounted just above the starter motor) is
called the "magnetic starter switch" on the diagram. Please see the
attached picture to see how I believe this is wired, and confirm whether I
am right or wrong.
I would rather ask silly questions now, rather than botch it up and melt
something upon startup.
By the way, the engine is in the car. This picture is of the "old" engine,
sitting alongside - a good model. If I do this again I will be sure to
attach the battery cable BEFORE I mount the engine - it's in a bad spot to
work on now.
Thanks as always,
a65tigrr
Re: dumb question #3 - solenoid identification
Post by a65tigrr »
No, that is not correct. The terminal on the starter connects to the wire coming from the ignition switch.Should be a black wire w? a white stripe.
Greg Steven Michelsen wrote:
> While pondering my unwired engine and my Coupe wiring diagram, I see that > what I believe is the solenoid (mounted just above the starter motor) is > called the "magnetic starter switch" on the diagram.  Please see the > attached picture to see how I believe this is wired, and confirm whether I > am right or wrong.
> I would rather ask silly questions now, rather than botch it up and melt > something upon startup.
> By the way, the engine is in the car.  This picture is of the "old" engine, > sitting alongside - a good model.  If I do this again I will be sure to > attach the battery cable BEFORE I mount the engine - it's in a bad spot to > work on now.
> Thanks as always,
> Steve
> > ATTACHMENT part 2 image/jpeg name=solenoid_identification.jpg
