Steve,
Looked at the URL that you posted on the wiring. Looks like your
on the right track. It might be a good idea to clean all the
connections, (pull back the plastic shield , clean real good, and the
coat the connections with some Dy-electric grease to prevent
corrosion). Also, you can buy (wire identification tabs) from your
local electric store, and affix them on each side of the connection
with an identification number so that it will be much easier if you
have to take out the engine again in the future. Hope this helps,
Nick
wiring
wiring
Here is a webpage that illustrates my little wiring meltdown a couple months ago...
Don't let this happen to you!
http://www.honda600coupe.com/fused_wiring_cleanup.html
